HVAC tech here!!
Discussion in 'The Wood Pile' started by SD Steve, Nov 14, 2019.
  1. SD Steve
    SD Steve
    South Dakota
    Hey guys, I know that we all burn wood, but if anyone has a propane or natural gas boiler or furnace, just send me a quick message. I am an HVAC Technician and I will tell you what might be wrong. If you can give me the symptoms, I will try my best to lead you on the right path to fixing your appliances. Remember, I also do cooling!!
  2. brenndatomu
    Mighty fine offer Steve! :handshake:
  3. saewoody
    saewoody
    Central CT
    I was going to say almost the exact same thing! But I was going to say:
    “That’s a mighty fine offer of you.”
    I guess great minds think alike.
  4. brenndatomu
    Matter of a fact, I just went back and "bookmarked" his post...never know when you gonna get in over your head!
  5. savemoney
    A while back, I was fortunate enough to converse with a tech on an appliance forum. My washer was having issues. He offered a lot of insight and that saved me a bundle of money in repairs as I was able to follow what he said and fixed it for a few more years. thanks for the offer. Lots of varied skills on this forum.
  6. Rush Battle
    Rush Battle
    WNC
    Well I’ve got a strange one for you! I have a house with a bunch of worthless prefab fireplaces. I’d like to offset some propane and heat pump heating cost with wood BTUs. It’s not ideal for placement, but I think I could fit a wood furnace like a Kuuma VF100 into the basement with my two heat pump furnaces with propane emergency heat that supply two separate floors. Any way to use the wood furnace to send heat to both systems?
    I thought of a multi-zone system controlling two motorized dampers, but finding three stage heating thermostats seems hard and I am not sure how to hook it all up exactly. Or I could just put a manual damper on the smaller system and send the rest to the bigger system.
    In any case, does it seem like the VF100 blower could continue to work when pushing against the furnaces blowers when they kick on? The VF100 won’t keep up completely as I have a pretty big house so heat pump or propane will still be used sometimes.
    Thanks for this great offer, and no worries if you don’t feel like tackling this one!
  7. TurboDiesel
    Welcome to the club, SD Steve ! :handshake:
    And thank you for this great offer !
  8. TurboDiesel
  9. wildwest
    Wyoming high plains
    What a kind offer!
  10. Thor
    Thor
    Genoa City,Wi
  11. SD Steve
    SD Steve
    South Dakota
    For you, you are going want to look at an add on fireplace, basically a wood stove that connects to your existing duct work/ furnace. You build a fire and the blower fan runs to push the heat into the house. They are a between $1000-$2000, but worth it if it's done right.
    Do not put in a zoning system! In my experience with zoning out a house, when one zone is calling for heat and the others are not you can potentially choked off your gas furnace or plenum heater causing it to trip the overloads and then you have NO heat. Just because the fan is still running at the same speed doesn't make more air move into the zone. Most duct work only adds pressure when you close dampers.
    And as far as thermostats go, look at the Honeywell's T6 Pro Wi/Fi, 3 heat , 2 cool thermostat. This is the one I install, and everyone loves them!!
