Husky 450 Rancher 450 Oiler
Discussion in 'Chainsaws and Power Equipment' started by Paul Dokken, Jan 21, 2022.
Tags:
  1. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I have noticed that I am only using about 1/4 of a tank of oil for every tank of fuel. I took the blade off and cleaned out the oil passage ways. I wonder if I need a new oiler? I'm wondering if this one will work? https://amzn.to/3FKCa3a My saw takes a 80 Links Pitch .325 Gauge .050 chain which seems like an odd size.
    I didn't see anywhere to adjust the flow. Is there a way to do this?
    Thanks,
    Paul
    JB Sawman likes this.
  2. coreboy83
    coreboy83
    NW of Twin-Cities
    The oiler on my 450 went to crap while it was under the warranty I bought. Luckily the fellow installed a metal oiler instead of the junk plastic one they come with. I also run a 18” x .058 and I feel like it oils better. 1/2 tank to full tank of fuel.
    JB Sawman and Rickyblazin like this.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I don’t think the oiler is adjustable on the 450. Just replace with better quality. My 455 uses 1/2+ tank of oil per tank of fuel.
    Mike in Okla
  4. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I can only find one kind of plastic oiler for my saw on Amazon. An other places to try?
  5. Paul Dokken
    Paul Dokken
    Waxhaw NC
    Would thinner oil help?
  6. coreboy83
    coreboy83
    NW of Twin-Cities
    I don’t think so. A 20” is simply too much for these saws. Not capable to provide enough oil. I asked far too much from my 450 for awhile. Had to upgrade. Nice tool for limbing and certain jobs
  7. Warner
    Warner
    Blade?
    coreboy83 likes this.
  8. Rickyblazin
    Rickyblazin
    Pottstown PA
    I agree i had a 2015 450 xtorq with 20 in bar and had alot of repeat trouble…the chain would always jump off and rip the clutch apart or damage the cover..i think the fact that 450s only have 1 bar nut mite have sumthing to do with it idk…after getting it repaired twice after very light use i finally said heck with mine and sold it for 200 bucks on Facebook marketplace…sold it in two days after listing it….
  9. Rickyblazin
    Rickyblazin
    Pottstown PA
    Keep the saw inside bar oil could jus be freezing up
  10. Va Homesteader
    Va Homesteader
    Central Va
    I run a 22 year old 55 rancher with a 20'' bar , uses 1/2 tank of oil to a tank of fuel . I keep my oil and saw in the house in cold weather and leave the oil jug in the truck while cutting.
    M2theB likes this.
  11. Warner
    Warner
    Bar oil can freeze? At what temp?
    Rickyblazin likes this.
  12. Va Homesteader
    Va Homesteader
    Central Va
    I've never had it freeze but have had it too thick to even pour . I think they make a winter oil as well. I'm cheap so just keep what I have warm . zone 7 central Va isn't all that cold compared to some of you in the north.
    M2theB likes this.
  13. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I will try putting it inside
  14. Rickyblazin
    Rickyblazin
    Pottstown PA
    I went the route of getting chinese amazon parts and regretted it good luck
    doesnt freeze but it will get thick and become useless
    Va Homesteader and JB Sawman like this.
  15. Rickyblazin
    Rickyblazin
    Pottstown PA
    also another thing to do if u havent already is takin a old hacksaw blade or putty knife and running it thru the bar to get all the gunk out of the groove
  16. Paul Dokken
    Paul Dokken
    Waxhaw NC
    I bought a new oiler and shaft and it still doesn’t use much oil. Would it be ok to try motor oil? Also does the oil only come out when the saw is level. I was doing a lot of vertical cutting yesterday and it still used about the same amount
  17. The Wood Wolverine
    Motor oil not a good idea. It has no tackifiers so it mostly slings off the tip. Stick w/ dedicated stuff. Not out of the ordinary, most new saws don't oil a lot. Your saw can be any orientation and oil will still flow to the bar and chain.
    Sandhillbilly likes this.
  18. coreboy83
    coreboy83
    NW of Twin-Cities
    Hate to say this, but that’s a major downfall to the 450. Can’t really get around it. I wouldn’t use motor oil
    M2theB and JB Sawman like this.
  19. buzz-saw
    buzz-saw
    Ct.
    I have winter grade bar oil for when it is really cold but rarely need it. I did use it a couple weeks back for the first time in years , when it was opened I wrote a date on it ; year says 2014. Nine out of ten times if it is that cold there is no cutting for me.
    The Wood Wolverine and JB Sawman like this.
  20. JB Sawman
    JB Sawman
    pennsylvania
    The 450 is a 18 inch bar saw at best 3.2 hp is really at its limit with a 20 did you check your oil filter in tank? if they get clogged the pump cannot move enough oil I do not know if you have a EFCO chainsaw dealer near you their winter grade oil works real well also Kinetic bar oil winter grade flows well the 450 is a completely different saw than the 455 or the older 55 rancher saws I will call the service line today at husky and see if you have any options on a better oiler Stay Tuned !! :popcorn:I will let you know JB
