Husky 40 - air filter.
Discussion in 'Chainsaws and Power Equipment' started by MikeInMa, May 25, 2018.
  1. MikeInMa
    Is anyone knowledgeable with this specific older model?
    I want to check the air fiktef, but can't figure out how to do so. Can't find an exploded drawing or video on the net. I only find videos that are for newer models.
    I'm finding the saw is bogging down after 20 mins of use. Fuel is fresh and works fine in my husky 435. So, I'd like to eyeball the air filter.
    When I pull the cover off, there's a white plastic cover, with fins, that I believe the filter is underneath. Nothing obvious to snap/unscrew to open it up.
  2. basod
    basod
    Mount Cheaha AL
    Chaz likes this.
  3. Redfin
    Redfin
    central Pa
    Does the saw go to wot out of wood? Sound like rpms are higher after warmed up?
  4. MikeInMa
    It fires up fine. Runs/cuts fine. Then, starts to labor after cutting for a bit. When it starts to labor, it doesn't want to rev up to full rpm.
  5. MikeInMa
    Coil was replaced about 18mos ago.
  6. basod
    basod
    Mount Cheaha AL
    Next time it's warmed up and does this pop the gas cap reinstall and see if it repeats
    Chaz likes this.
  7. MikeInMa
    Will do. Thanks!
  8. MikeInMa
    Cracking the fuel cap open, closing and restarting doesn't change the behavior. Just doesn't want to rev up to full rpm. Time for a visit to the saw doctor, I guess. There's been lots of hours and many cords of wood since its last visit.
  9. Redfin
    Redfin
    central Pa
    Have you changed the plug? Sounds spark/ignition related.
    basod likes this.
  10. MikeInMa
    Thought of that. Haven't done it yet. That'll be done before the Dr visit.
    M2theB likes this.
  11. MikeInMa
    New spark plug took care of it.
    Now, if I could only figure out the air filter. I noticed a hex/allen screw just under it. Didn't have the Allen wrench handy, but I will. If that's not it, then maybe someone at the gtg will point me in the obvious to them, direction.
    Thanks to all for the suggestions.
    M2theB and basod like this.
