Husky 372XP Compression
Discussion in 'Chainsaws and Power Equipment' started by JRSDWS, Feb 20, 2014.
  1. JRSDWS
    JRSDWS
    Central Illinois
    Looking at a used 372XP for sale. It starts and runs okay....kinda dirty and in need of some TLC and the compression is 130psi. Isn't this on the low end of comfortable?
    I'm a newbie with the saws so bear with.....could it just need new rings? I have requested pictures of the piston and cylinder from the seller.
  2. mdavlee
    mdavlee
    It is a bit low. Their gauge could be off or something else. Don't get hung up on compression readings alone. If the piston and cylinder looks good then don't worry about the compression.
    HoneyFuzz likes this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    Agreed... Many of these didn't have super high comp even when new. If the cylinder is good, a new piston and rings will get it right back where it needs to be.. Pretty cheap too..
    HoneyFuzz and mdavlee like this.
  4. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I agree with these fellas ! I use to work on mostly old Homelite SXL's and XL-12's and such . They would always get on my work bench with 120 psi . Sometimes as low as 90 psi . They ran really well actually at 120 psi..which was probably not too far from what they had new . The 90 psi ones ran good too ! Recently sold a Husky 261 with 115psi...the thing ran super actually !!! Saws always seem to let a fella know when the psi is too low to go :)
  5. JRSDWS
    JRSDWS
    Central Illinois
    Cool thanks guys!!! Cylinder and piston look good!!!
    Hedgerow and HoneyFuzz like this.
  6. mdavlee
    mdavlee
    Sounds like its good to go.
  7. clemsonfor
    I have a 372xp x torque model with 130ish compression. I think 135 to be exact? It runs like a violated ape. I have a cancer ring to put into it but it runs so well I have not torn into it yet to install it.
    Certified106 likes this.
  8. HittinSteel
    HittinSteel
    Wooster, Ohio
    Mine was 140 and ran strong before being taken to the next level.
    clemsonfor and HoneyFuzz like this.
  9. clemsonfor
    Hahaha a "cancer ring".
    Just had to leave that one!
    But seriously I have a Caber ring to install.
    cnice_37 and Certified106 like this.
  10. DexterDay
    DexterDay Administrator
    Northeast Oh
    130 isn't terrible as noted. A set of Caber rings is less than $15 and will make it run better than new :thumbs:
  11. MasterMech
    Is the seller at a high altitude? That also can affect compression readings.
    clemsonfor likes this.
  12. JRSDWS
    JRSDWS
    Central Illinois
    Nahhh....mid Wisconsin
  13. Hedgerow
    Hedgerow
    SW Missouri
    Funny thing about the 372's..
    They like a little extra compression, but their design don't need 170-190 pounds to really haul the mail..
    I've seen stockers with 140 that really put out some power.
    Their design is to move fuel and air, and they do a real good job at it...
    A little extra comp is just some added torque... They'll idle a bit lower too..
    Like a dirt bike...
    DSS and clemsonfor like this.
