Humpty Dumpty had a fall
Discussion in 'The Wood Pile' started by The Wood Wolverine, Apr 19, 2025 at 7:57 PM.
  1. The Wood Wolverine
    This hasn’t happened in a long time!
    This was a fresh expansion of my stacks so the ground sunk a bit helping the fall. Glad it wasn’t too bad to fix.
    Should be good for another couple years.
  2. Chud
    Chud
    NC
    They look like cut up 2x4’s :yes:
  3. stuckinthemuck
    stuckinthemuck
    Great job at the splitter to make it easier to stack!!!
    Chvymn99, Horkn, eatonpcat and 6 others like this.
  4. Backwoods Savage
    It can happen to anyone Jason. Fortunately there was not too much work fixing it.
    Chvymn99, Horkn, eatonpcat and 8 others like this.
  5. JDU
    JDU
    Perry County, PA
    Hate when that happens, but easy fix there. I have leaner stack that defied gravity so far by not falling over, so I started pinching pieces off the top last couple weeks to lower it. Has worked so far and will straighten it out when done burning for the season, or when it does fall over.
  6. 38f20
    38f20
    Loganton,PA
    I just partially re-stacked one of my ranks on Thursday evening. I was surprised the same thing hadn’t happened yet, I knew it wouldn’t be long so I nipped it in the bud.
  7. buZZsaw BRAD
    Mebbe it was seismic activity? :D Last time I had a stack topple it was due to uneven drying and it fell forward.
  8. Chud
    Chud
    NC
    When I have a stack fall it can usually be blamed on Hickory.
    Chvymn99, brenndatomu, Horkn and 3 others like this.
  9. MikeInMa
  10. The Wood Wolverine
    My end cribbing was leaning out for a while. I knew it wouldn’t take much and procrastinated too long. Glad it wasn’t a lot of wood.
    I think it was one of the several very high wind storms we’ve recently had. 2 of my rubber tarps had been partially blown off and they’re held down with small cinder block.
  11. Horkn
    That plastic pallet looks like it is bowing quite a bit. That appears to be the heavy duty kind of plastic pallet too?
  12. The Wood Wolverine
    It's a light-weight one. Next round of wood to go there will get the metal-reinforced type and shouldn't be an issue. I'll probably give the lights away when that happens. Here it is April/May'23:
    It's a really wet area of the yard and TBH, that's a good clip of weight! Can't complain, I should have leaned it in a bit vs. going straight up too.
  13. Horkn
    Ok. Those are at least the middle weight kind and not the super light weight ones.
    eatonpcat and Backwoods Savage like this.
  14. brenndatomu
    :whistle:;) :D
    eatonpcat, MikeInMa, Chvymn99 and 3 others like this.
