How Would You Fell It?
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jun 5, 2023.
  1. buZZsaw BRAD
    Have to take down this dead ash spar that's in my way where i'm working. How'd you go about it FHC? :D
    IMG_3368.JPG IMG_3366.JPG IMG_3367.JPG IMG_3370.JPG IMG_3369.JPG They did a nice job cutting this joist around it. IMG_3374.JPG IMG_3373.JPG I wouldve just moved it a couple inches.:picard: Ive worked around trees while roofing, but first time on a deck!
    metalcuttr, JDU, T.Jeff Veal and 10 others like this.
  2. Dok440
    Dok440
    NorCal
    ALAP it and pretend it's part of the deck?
  3. Bill2
    Bill2
    New hampshire
    I'd leave it be and use it to rest my beer on.
  4. spotted owl
    spotted owl
    PNW
    First you gotta spit a couple times. Then hold yer mouth just right. March right in there and attack that sucker. Take no prisoners, wedge as needed, probably won’t need a jack.
    Don’t forget to stag off your britches with spenders out so you look like a reel logger too. Above all video, we need a video how with proper technique.
    Owl
  5. Sirchopsalot
    Sirchopsalot
    medium city in CT
    I was thinking similarly....secure it to the joist, trim it down, put a table on it for serving drinks.....
    But if it has to go, and you're not replacing the decking, small chainsaw, bar pointed down to the middle of the stump, creating a v shaped bowl. After that, one of those reciprocating saws to plunge-cut the rest of the stump below the deck..
  6. FarmerJ
    FarmerJ
    Minnesota
    I’d make it a table base. Put a couple bar stools around it…
    metalcuttr, JDU, JimBear and 7 others like this.
  7. brenndatomu
    Yup, frame around it and use it for a table or something.
    If it has to go, then I'd use a couple lbs. of Tannerite :D ;)
    metalcuttr, JDU, Stephiedoll and 8 others like this.
  8. FarmerJ
    FarmerJ
    Minnesota
    I’d crawl under the deck and remove it below the joists
  9. MikeInMa
    I'd use a chainsaw. :cool:
  10. buZZsaw BRAD
    Im demoing entire deck. Ill post more pics later.
  11. buZZsaw BRAD
    :rofl: :lol: :salute: I was waiting for that response. You didnt disappoint Mike!
  12. jo191145
    jo191145
    Ct
    Need a sky hook for that job, no doubt.
  13. ole
    ole
    Rock County Wisconsin
    then swedish candle it!
    done!
  14. FarmerJ
    FarmerJ
    Minnesota
    mini X time. Take it out as a stump.
    just call 811 first
  15. The Wood Wolverine
    I'd remove deck first, then chain it and try to pull the stump out w/ truck or something heavier. The higher the stump the more leverage for success.
  16. RCBS
    RCBS
    Over here
    Sizwheel looks to be the only viable option.
  17. FarmerJ
    FarmerJ
    Minnesota
    Where would you like this unloaded at.?
    i’ll be loading it tomorrow morning.
    it might be on the small side though.
    metalcuttr, Chaz, brenndatomu and 6 others like this.
  18. buZZsaw BRAD
    Pics from this morning when i started. He said i could cut it down. Not sure of future deck plans but living space being extended out about 8' even with where the lower deck was attached. IMG_3377.JPG IMG_3378.JPG
  19. T.Jeff Veal
    We need that to grind the stumps on that 3 acre Plantation job we did. Bring it to GA
    brenndatomu, metalcuttr, Chaz and 3 others like this.
  20. T.Jeff Veal
    Well, to cut it down, as MikeInMa said, ise a chain saw, but your CAD will kick in, and you'll have to get a MS661 or MS881 with at least a 50" bar, might still have to double cut it to reach across...:p:p:salute:
