How to weld circa 2020
Discussion in 'Everything Else (off topic)' started by Yawner, Aug 29, 2020.
  1. Yawner
    Yawner
    Louisiana
    When I was young, about 1968-1978, I took shop because my dad was a farmer/rancher and I learned how to use a cutting torch and arc weld. It might be officially called shielded metal arc welding -- (https://en.wikipedia.org/wiki/Shielded_metal_arc_welding)
    I had to fix/fabricate this and that on the farm/ranch. I didn't do a ton of it but I was okay at it. Most welds seemed to hold. Not everybody can weld, not sure why, lol.
    Has anything changed in welding for the general population of DIYers? Do people still use the same type arc welders we had back then or is there some new technique that is easier? If there is something different, how would one learn that? I actually only one guy who welds anymore and it's just a sideline and there used to be a ton of full-time welders around here. Youtube, lol?
    Point being, it would be handy to have a welding machine sometimes. Thanks!
  2. sirbuildalot
    sirbuildalot
    Mass
    Most people now use MIG welders which is a wide feed “gun” with a trigger. Much simpler to learn than stick welding.
  3. Backwoods Savage
    I too welded in my younger days. Didn't really care for it then so never continued. I do remember our shop teacher thought I should continue with it but he was wrong about other things too.
  4. Andimus Prime
    Andimus Prime
    NW NC
    I took a few welding classes in high school and college. Wire welding is waay easier than stick. Our college welding class was 100% stick welding. :picard:
  5. brenndatomu
    Stick welding is still common...you can buy a used buzzbox cheap! But for many home DIY'rs, the ease of using, and the prevalence of half decent sub $200 MIG welders has made these the go-to choice for most...
  6. Horkn
    I learned right out of HS. Big cart gas MIG units. Later they also got TIG welders and I was welding tiny little SS parts for medical use.
    Later, for my own use we got a small Hobart mig unit. It ones 120v, gas or gasless ( only used it gasless), and it works very well. I've welded up trailer brackets, wheel chicks for motorcycles, snowmobile carts, deer stands, etc.
    Dad had/ has an old stick welder, but every time I tried it, it didn't work fer chit.
  7. Chaz
    Chaz
    Southwestern NY
    I don't have a welder,and haven't done any welding in many years
    I know the MIG's are fairly inexpensive, but what gauge metal can be properly joined with MIG?
    I was always under the impression that MIG is great for thin metal, but no comparison to arc welding on thicker steel.
    Can you get good penetration with the average MIG welder?
  8. brenndatomu
    These are separate/different from the trophy girls? :whistle: ;) :D :rofl: :lol:
    1/8" and down for small welders...1/4" and down for larger ones...roughly...
    gspfisher, Chaz, Horkn and 1 other person like this.
  9. Chvymn99
    I mainly use my small 110 Lincoln. I have access to a larger 220 at work. Plus I have a stick welder... but I haven’t used it in many moons..
    I learned at a community college, that work paid for... but it was my Uncle that fine tuned my abilities...
    Chaz likes this.
  10. sirbuildalot
    sirbuildalot
    Mass
    My fathers 220v Millermatic will easily do 1/2”, in fact I’ve seen him weld up to 3/4”. Keep in mind you can adjust a mig with knobs for amps and speed for different thickness metal. There is actually a chart under the flip up cover that tells you what to set it to for a certain thickness metal based on your wire diam.
    gspfisher, Chaz and Chvymn99 like this.
  11. brenndatomu
    Yeah, the commercial units will do heavy plate...but I thought OP was asking about DIY project sized welders?
    Even with a big welder, once you get into thicker stuff you really need to bevel and take multiple passes to build up the weld...not unlike stick welding.
  12. sirbuildalot
    sirbuildalot
    Mass
    You’re probably right. I remember asking my father his opinion on a 110/120v wirefeed and he said why throw your money away. It’s too small and limited. Keep in mind he welded in a commercial shop for about a decade in the 80’s. Pretty neat, they did a lot of gun parts, and a lot of EM and Westinghouse motor frames, as well as a bunch of other stuff. Now if I could just convince him that he needs a plasma cutter.
  13. Nitrodave
    Nitrodave
    Grayling Mi.
    I prefer Tig welding.... but I’ve burnt up ALOT of pounds of filler rod with them.... once you learn how to Tig weld, everything else is just a manure spreader . :D
  14. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I use my welders quite a bit. My smaw (stick) will also do gtaw (tig) is for thin and thicker metals. My gmaw (mig) I will use up to 3/8" on steel if it's clean. Mig welders are constant voltage machines which means you set the voltage and the amps are adjusted with wire speed. I had a 115v Lincoln mig for a very short time and sold it for a 250 amp machine as you can make a very nice looking bead with a 115v. that does not penetrate the base metal.
  15. AZJustin
    AZJustin
    Desert SW
    Learned on stick, hated it even though I did well. 1980's ish
    Went to 110v wirefeed and the world was a different place. I was taught (correctly) how to do multiple passes which always passed muster and then got a 220v MIG and the world changed again Burned 1/2" which was great, but ended up back on a 110v which has been my go to machine for many years now. Argon/CO2 mix has always been a requirement and you will know why when you switch over. Still keep the flux setup around just in case, but try not to use it.
    Eastwood makes a great 110v machine, just my 2c.
    Chaz, brenndatomu and Chvymn99 like this.
  16. Horkn
    Lol. Chocks. :whistle:
    My small mig does 1/4" no issues. It is a more expensive small welder though
  17. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I had the sp140 Lincoln. Like I said I sold it and went bigger. Flux core will weld a bit thicker than er70 with c25 mix.
    Chaz and brenndatomu like this.
  18. chainsawsoldier
    chainsawsoldier
    NE Kansas
    I have several welders and access to several more. I have an old tombstone Lincoln buzz box for repairing most of the farm equipment out in the garage. I also have 2 110v MIG welders, a Harbor freight W/flux core and a Lincoln with CO2 gas. And I have the repair trailer with a Hobart 10K welder/generator that I bought when I was welding a bunch of pipe fence.
    i also have access to the neighbor’s shop, where they used to run a metal fabrication business. They have a couple 400 amp power supplies with wire feeders on top. One is set up to run dual shield, allowing one pass welding of 3/8” plate.
