How to replace a rear main seal question
Discussion in 'The DIY Room' started by Jack Straw, Feb 24, 2019.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    At work we have a 1988 Dodge Truck with a 318 engine and a manual transmission. It only has 17k miles on it and is in excellent condition. I use it as a service truck and travel to several locations with it. It appears that the rear main seal is now leaking rather bad now. On the Advance Auto website it appears to be a 2 piece seal. What would be involved in reaplacing that? Thank you!
    Screwloose likes this.
  2. papadave
  3. ironpony
    ironpony
    Mid Ohio
    Sounds about right glad someone else typed it out.
    Screwloose, Jack Straw and Chaz like this.
  4. papadave
    Never done one, but pretty easy to find the info.
    Screwloose and Jack Straw like this.
  5. brenndatomu
    1988 should have a 1 piece seal...I think. If not, that's what I would put back in, if at all possible. Shouldn't be a bad job (especially if its 2wd) unless things go sideways on ya...as they tend to do on 30 YO vehicles.
  6. Creekin
    Creekin
    Manitoba
    Number of years ago i did one for someone, said it was the second one in a year, hmmmmm
    Found the crank thrust bearing was toasted allowing the crank to move almost 3/8" in and out, which took out the seal, ended up swapping the crank
    Hopefully yours is just a seal!!
