How to clean wax off a brick hearth?
Discussion in 'Modern EPA Stoves and Fireplaces' started by fox9988, Dec 29, 2013.
  1. fox9988
    fox9988
    NW Arkansas 72717
    My wife spilt wax on our hearth, don't ask:rolleyes:
    Propane torch and burn it off? At least heat it up and then clean it with a rag?
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    fox9988 likes this.
  3. NortheastAl
    NortheastAl
    Putnam County NY
    We used to get oil out of slate by adding denatured alcohol and lighting it on fire. Worked every time. Wax is tougher, but trying a torch worked great on my deck when knocked over candles spilled wax on them. Waterproofed the deck too! And, you couldn't see the wax. Wanted to melt wax all over the deck and torch it in after that. It lasted for years.
    fox9988 likes this.
  4. blujacket
    blujacket
    Kettering, OH
    Put a paper grocery bag over wax and run a hot iron over it.
    Mitch Newton, papadave and fox9988 like this.
  5. papadave
    If you try to wipe it up after heating, it'll just smear.
    I'd try the alcohol/burning it method.
    Could leave it there for "character".
    If it's a blob, most should pop off when cool.
  6. fox9988
    fox9988
    NW Arkansas 72717
    It's more like a smear. She wiped most of it up while it was still hot.
  7. chris
    chris
    SE WI
    Hit with co2 to freeze it solid and get off as much as possible, then use iron with paper towel on top of wax to try and pull up as much as possible from pores of surface. Problem with disolving it is that it goes both ways into pores of surface and on to cleaning material.
    fox9988 likes this.
