How do you tie up your garden tomato plants?
Discussion in 'The DIY Room' started by don2222, Jul 1, 2023.
  1. don2222
    don2222
    Salem NH
    We tried using 2 - 2x4s and a piece of electrical conduit with dental floss Tape for string. It works ok but
    What do you use?
    Pics please if you can. :)
    Mods - can you fix the spelling of tomato in the title please? Darn spell checker. :)
    Also can you fix it so we can change the title. The other sites allows us to do that. :)
    Eggshooterist likes this.
  2. Dok440
    Dok440
    NorCal
    We grow them in pots and just use the home store tomato cages. Eager to see what others come up with. Dental floss- how does it hold up in the sun?
  3. don2222
    don2222
    Salem NH
    The floss holds up just fine, fairly cheap and easy. :)
    Do you use the cages like the ones at Tractor Supply?
    How many plants per pot?
  4. don2222
    don2222
    Salem NH
    Hello
    I just found this new video that shows how to support the tomato plants with new plastic support clips!!
  5. SimonHS
    SimonHS
    Yorkshire, England
    Chaz likes this.
  6. Wolley
    Wolley
    Maine
    I use single wooded stakes for larger tomatoes. Tie with cotton rags or twine. Plum tomatoes I gave up on tying up an let them go. They seem to do fine.
    Biddleman likes this.
  7. Ohio dave
    Ohio dave
    Akron, OH
    This is the first year I tried it. But I am trying to train them to grow up on a cattle panel
    RCBS and Ron T like this.
  8. billb3
    Indeterminate I grow up a vhf antenna with the green garden velcro. I've only run into a problem with this method with really big, heavy beefsteak tomatoes where the whole thing can sometimes collapse. It helps to use the antennas that are losing their gel coat and getting rough .
    I mostly gave up on beeefsteaks as I just don't get enough per plant to be worthwhile.
    Determinate variety I use a round cage made from concrete reinforcement screen. Works really well for Celebrity tomato.
    Plum and cherry I've been not pruning and growing on fence. Yeah, I get far too many tomatoes all at once but it's a lot less work.
  9. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I used to use the metal cages or stakes but don't like either (and I have way more tomato plants than cages). This year I'm going to try t-posts with twine and the 'Florida weave' method. Hoping to get the trellises up this week (zone 5b so only transplanted into the raised beds a few weeks ago). I'll take pictures once it's done.
    Chvymn99 and Chaz like this.
  10. Dok440
    Dok440
    NorCal
    Those exactly, one pre plant. We only have four plants. I'm going to try that dental floss trick, I have tons of small containers from the dentist.
  11. don2222
    don2222
    Salem NH
    Very good
    You have to get the floss that is marked as Tape which holds up better than the small string type. :)
  12. Eggshooterist
    Eggshooterist
    Erff
    We use a combination of things based on the variety of tomatoes. The Roma plants get the cages and if needed, fiberglass driveway marker with tomato clips to steady them until they bush out enough to fill the cage more. The Sun Sugar cherry tomatoes get really tall so we plant them under this A frame of livestock fencing panels. We snake the branches out through the squares and will use clips and stakes, if necessary, for added support.
    IMG_20230703_205145397.jpg IMG_20230703_205157750.jpg IMG_20230703_205138930~2.jpg IMG_20230703_205225319~2.jpg
  13. JoeyD
    JoeyD
    I use this stuff along with metal fence posts.
    What I like about it is that it holds really well and I reuse it year after year. I'm currently on my third year and by the looks of it I'll get at least two more years.
    eatonpcat and don2222 like this.
  14. EODMSgt
    EODMSgt
    Put up some Florida weave trellises today and am using the plastic clips with them. Not sure I really like the style as the t-posts aren't that sturdy in the stock tanks. I'll make them work for this year, but I think I may move on to cattle panels for trellises next year.
  15. lukem
    I used to tie them up to a stake. Last year I made big cages from concrete rewire and will never ever go back.
  16. Ohio dave
    Ohio dave
    Akron, OH
    I just saw a video of someone setting up that same system. Doesn't look like that trellis material will last very long. The person on the video was trying it for the first time
  17. buzz-saw
    buzz-saw
    Ct.
    Same here , I certainly don't over engineer it. I have always used strips of cloth to tie with , I was told to do so from an old timer. I guess the thought was the cloth is easier on the plant and doesn't cut into the stem.
    I don't have a garden like I used to , just a small one for the two of us.
    When the time comes I have no problem supporting the local produce guy.
    eatonpcat likes this.
  18. EODMSgt
    EODMSgt
    The twine isn't heavy duty, so I'm only looking at getting one season out of it. It's actually sold as 'tomato plant twine'. I paid around $14.00 for a roll of 6300 feet, and already had the t-posts, so even if the twine only lasts one season it's cheap and I have plenty for years to come. I'm trying the same system with some of my cucumber plants and the twine is holding up so far (plants are almost two feet tall so far).
  19. Ron T
    Ron T
    Northeast Ohio....Bowdil
    I've got 4 hillbilly plants growing up a pice of wire fence this year.
    RCBS likes this.
  20. RCBS
    RCBS
    Over here
    Cattle panel. Old twine.
    Ron T likes this.
