Hot start only with choke on
Discussion in 'Chainsaws and Power Equipment' started by pantelis, Nov 30, 2015.
  1. pantelis
    pantelis
    Europe
    So what can be the problem and a saw can start only with choke on even if have cut wood and is enough hot ?
  2. Oldman47
    Oldman47
    Illinois
    You may have an air leak that makes the standard mix too lean for an idle start.
  3. pantelis
    pantelis
    Europe
    agree with this but now tell me why the saw start cold after 2-3 pulls works ok and the dificulties start when you stop the saw and try to restart it again after one minute for example ?
  4. lukem
    Air leak develops as saw warms and expands? Closes back up when cold...
    pantelis likes this.
  5. pantelis
    pantelis
    Europe
    thats i like to listen :yes:
  6. Bret Hart
    Bret Hart
    Central NY
    What saw is it?
  7. pantelis
    pantelis
    Europe
    husqvarna 61 but i dont have in my hads yet just what the friend say
  8. Bret Hart
    Bret Hart
    Central NY
    Figured I might be able to help with a manual. Not many husky manuals but I can check tomorrow.
    94BULLITT and pantelis like this.
  9. Bret Hart
    Bret Hart
    Central NY
    Lukem has a good starting point. Also check tank vent and fuel filter.
  10. pantelis
    pantelis
    Europe
    Thank you friend
  11. pantelis
    pantelis
    Europe
    lukem is in about 99,9%
  12. WV Mountaineer
    WV Mountaineer
    Princeton, WV
    Air leak no doubt. God Bless
  13. pantelis
    pantelis
    Europe
    I have two senarios in my mind
    1) leaks somewhere after the saw been hot ( seals , gaskets , intakes )
    2) not to good piston ring or piston after they cylinder became hot and expand the ring is not so good and the compression fall so the saw start dificult
    but maybe i am wrong in the second senario , i just make some thinks
  14. lukem
    I had a dirt bike that would do the same thing. Turned out to be a leaking jug gasket.
  15. pantelis
    pantelis
    Europe
    to tell you the truth i do not believe too much in religions , but if is for repair the saw i will start a little :D
  16. pantelis
    pantelis
    Europe
    tomorow friend i put it in the bench i tested for leaks cold and hot , cold compression, hot compression everything i make it screws until i find what it is
