Hopefully this gets it.
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, Mar 5, 2015.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    044 project on a rainy/snowy day.
  2. foragefarmer
    foragefarmer
    Central, Virginia
    Back together. Spent 20 mins. Crawling around on the floor looking for one of the wrist pin retainers.
  3. prell 73
    prell 73
    ia
    Sweet job
    clemsonfor likes this.
  4. foragefarmer
    foragefarmer
    Central, Virginia
    Back together.
  5. foragefarmer
    foragefarmer
    Central, Virginia
    Popped on the 4th pull.
  6. Gasifier
    Nice work.
  7. foragefarmer
    foragefarmer
    Central, Virginia
    Anyone had a loose LA screw? I think this one is moving on its own.
  8. RJames
    RJames
    I've been told I have a few screws loose but never the LA:D
    Couldn't help it.
    crzybowhntr, Chvymn99 and Deacon like this.
  9. XXL
    XXL
    Ontario, Canada
    Nice!
    I don't know, looking at the first pic and then the video of the PH running reminded me of this.
    crzybowhntr, foragefarmer and Deacon like this.
  10. NewToStihl
    NewToStihl
    Central Indiana
    That's crazy, never heard of that, but anything is possible. Does it seem to move excessively easy with a screwdriver?
    foragefarmer likes this.
  11. DexterDay
    DexterDay Administrator
    Northeast Oh
    Nice job! Your "0" series is growing very quickly my friend! ! :) I like it!!
    That is normally the tightest screw. But anything is possible.
    Do you have a hardware store with small spring stock?
    clemsonfor and foragefarmer like this.
  12. foragefarmer
    foragefarmer
    Central, Virginia
    Screw seems looser that it should. Snowed hard in the afternoon here and I packed in trying to tune the saw after the video. We got 6" in 3 hours so I will have time to pull the carb tomorrow and take a good look.
    The guy I got the 044 from had about 20 268,272,371,372 carcasses sitting around as well but would only part with the nasty old Stihl. I tried hard to get them but he wouldn't budge. He has my number if he changes his mind. :vulture:
    clemsonfor and DexterDay like this.
  13. foragefarmer
    foragefarmer
    Central, Virginia
    Pulled the carb and the LA screw is easy to spin with my fingers. What is that spring theory DexterDay?
  14. Gunn
    Gunn
    Plover, Wi
    You try stretching the spring out a little. That should add some extra tension.
  15. foragefarmer
    foragefarmer
    Central, Virginia
    No spring present? Zama c3m
    Gunn likes this.
  16. Machria
    Machria
    Long Island, NY
    Nice work! That looked like it had some mileage on it, huh? Says a lot for Stihl....
  17. clemsonfor
    Pull the screw and put a spring on the shaft where it goes in between it and the head to give tension on it. Can't picture how there attached in my head right now? I know there pointed and the throttle plate rides on the point. Just can't picture where it screws into??
  18. foragefarmer
    foragefarmer
    Central, Virginia
    I sat down and googled the carb and it is missing something called a "friction piece" looks to work something like a detent. And it is missing.
    Problem with a spring where you describe is it is cone shaped all the way down and the spring might interfere with adjustments.
  19. foragefarmer
    foragefarmer
    Central, Virginia
    Thanks, picked it up a couple weeks ago for very little. Top end was toast from having run lean. It was definitely rode hard and put up wet. Nice to breath new life into a beat up old work horse. :)
