Honda Generator EU2000i
Discussion in 'The DIY Room' started by wildwest, Oct 10, 2014.
  1. wildwest
    Wyoming high plains
    Dear husband wants a giant diesel generator to run the house or fifth-wheel, it's not in our budget.
    I have ridiculous heating needs so I compromised with a little honda to atleast run the pellet stove when the power is out (rural area, not a big priority for e- company:headbang:).
    Turns out the electrician was wrong, said he could hook it up to the fifth-wheel power pole in the backyard and could relay back to the house to run the water pump, fridge, and pellet stove. Bummer, it will not, no 240 on the honda......not shipping it back to east coast overton's.
    Atleast I will still have heat :) been without water and lights many times.....
  2. OhioStihl
    OhioStihl
    Southern Ohio
    You should be able to run the pellet stove and a light with the Honda. Start up of the pellet stove might suck the amps but once it is running you should be good. They are good little generators, I like the portability of them.
    wildwest likes this.
  3. Fanatical1
    Fanatical1
    I have the ue2000, great generator, but no 240v. You can always get a plastic barrel with a lid, fill it with water and a half cup of bleach and use it for flushing your toilets if need be.
  4. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Which one of those thing are 240v?
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    I know Honda makes great genny's but have no idea of what models are what?
    Isn't the smaller Honda enough to at least run the stove and a few other small things?
    Why the need for the big one? confused :loco: :crazy:
  6. KaptJaq
    KaptJaq
    Long Island, NY
    Do you only need 240 to back-feed via the 5th wheel outlet? What are the power ratings on the water pump and stove? Both units should have a plate with the volts and wattage. That 2000 watt unit should be able to run your stove easily. The only big draw on the stove is the igniter. Once the stove is started there should be enough to run the water pump or fridge. The only hassle would be to get power to each unit. If you cannot back feed into the house you have to run lines, extension cords, to each unit.
    First get the power requirements of the appliances and pump you would like to run. Then we can figure out how to get power to them.
    KaptJaq
    Ps. I don't like the idea of back-feeding a generator into a house. Too many variables that may cause problems and the possibility of hurting the linemen trying to fix the outage.
    KJ
    IHATEPROPANE and wildwest like this.
  7. 343amc
    343amc
    Northeast Lower Michigan
    I have a Champion 2000 watt inverter generator. Its pretty much a reverse engineered Honda. It runs my pellet furnace, the fridge and a couple lights. It got me through a 36 hour power outage last December and kept the house warm and food cold. It sips gas too.
    papadave and wildwest like this.
  8. wildwest
    Wyoming high plains
    I think its the RV post the electrician installed in the back yard that needs the 240v.
  9. wildwest
    Wyoming high plains
    His work has an 8000 (?) watt...He wants to power the entire house LOL. My only priority is heat :fire:
  10. wildwest
    Wyoming high plains
    Good advice KJ about repairmen, that did not occur to me. Is there is something that can prevent it going back to power lines? Wonder if the electrician already installed something like that (if it exists) on the RV post for safety?
    I am prepared to strew long extension cords through a window and across the floor when needed, no worries here:smoke:Going to get the watts and volts tonight, I appreciate the help! The pellet stove and pump are both 110 plugs, the generator has 2 open receptacles.
    Nice to meet you~
  11. Stinny
    Have one just like it. Should be able to run just your heat no prob. If elec's out for a long time... turn heat off for about 20 minutes to run your fridge back up to temp, then, back to running just your heat. Yup, no 220, so no well pump. We added an aux 5 gal fuel tank (like a boat tank) that adds a much longer run time than the 1 gal in the gen itself. Good gen. Be sure to give it LOTS of room around it for cooling, if it's inside a remote building. Puts out a lot of heat.
  12. wildwest
    Wyoming high plains
    Great tips! Our plan was to set it outside when in use, not taking any chances :)
    My IS heats my home and Stinny like this.
  13. Stinny
    Do you have an out building/shed that it could be kept in? My son is going to have that same gen in his garage about 75' from his house. Same set-up as I just described. He'll be able to set it on his bench and just shoot the exhaust into the rest of the garage as it's so big... no need to vent outside. Just leaves a window open a bit. When the weather is lousy, a gen outside is no fun.
  14. KaptJaq
    KaptJaq
    Long Island, NY
    There are relatively inexpensive interlocks that can be used to prevent the generator from energizing the street line. The problem with them is that they force the outlet you are using, in your case the RV outlet, to become a dedicated generator line. When the generator circuit is active the street service drop is disconnected. When the street service drop is active the generator line is disconnected. These are usually installed at the main circuit breaker panel.
    For a small generator with a couple of specific tasks extension cords are usually the cheapest and most effective solution.
    KaptJaq
  15. Gasifier
    Congrats on a nice generator wildwest, be careful about listening to Stinny. Stinny is planning on just moving to camp for good if the power ever goes out at his house again.
  16. nate
    nate Banned
    Palmer, AK
    Go to an auction and get a diesel gen set for cheap.
    I bought two last week, one a 7.5k the other a 12k for $900 total. Kubota motors on both.
  17. wildwest
    Wyoming high plains
    :picard:Our power was out for a few hours today. By the time I tracked down DH who was out plowing snow it was 60* in the house :shiver:. On his second pull on the new genny, it's never been run, the cord tangled, no third pull, thank god the power came on soon after!! Then he hooked up the new pellet stove to an inverter attached to my truck, it wasn't enough :rolleyes: Poor guy, after messing around with e- cords, genny and truck, he came in frozen from the sub-zero temps, then the power came back on.
    I'll see if I can disassemble it tomorrow and rewrap the pull cord. Is that hard to do?
    Stinny likes this.
  18. Stinny
    Please take progress pics of how it goes. Last time we had our Honda 2000i serviced, I asked the guy if it was possible to start it if the rope broke, etc. He said no and that getting at the rewind, and changing the rope, was a bear. Hope he was just prepping me for extra time needed to do it... dunno. My son stores it for the winter and I've told him to baby the pull rope, every time we're talkin' genny. Good luck.
    Looks like your new insert (is that usable yet) came in handy? I see you guys are getting awful cold temps now.
  19. Highbeam
    Highbeam
    I backfeed my home with a legal interlock kit and a cheap champion 4000 watt genset that makes 240 volts. It was the smallest 240 genset that I could find. To get a nice, quiet, idle down, honda inverter with 240 output you need their 6000 watt model at 4000$. That's right, 4000$!!! The newest ones are even fuel injected and get pretty good gallons per hour.
    Your electrician absolutely could have made it work though. Being traditional, safe, and easy was apparently not an option through. You can backfeed through any plug to the main panel where you can then charge up circuits.
    With a genset as small and easy to move as that honda 2000, I recommend cords.
    KaptJaq and wildwest like this.
  20. wildwest
    Wyoming high plains
    Thanks Stinny. Yes the insert up and running! Just in the nick of time :) No time for new stove small break in burns, it was initiation by fire (pun intended) :rofl: :lol:
    eatonpcat and Stinny like this.
