Homemade 4 way hydro wedge meets it's match
Discussion in 'Chainsaws and Power Equipment' started by metalcuttr, Mar 16, 2025.
  1. metalcuttr
    metalcuttr
    western WA
    Made this wedge a couple years ago. Has worked fine for kindling splitting and rounds up to 11-12 in Doug Fir and Madrone. I was splitting up that Cherry I recently got. Worked fine on the rounds, even really knotty ones. I tried it on a gnarly twisted crotch and it split but not without consequences! When I repair this one I will heat dull red and quench. Even though it is mild steel, it will toughen it a bit. If it fails again, I will purchase some alloy steel for the wings!!
  2. BuckeyeFootball
    BuckeyeFootball
    What brand splitter did you have this on? If you can fab one up for a Champion Id gladly pay for one.
  3. metalcuttr
    metalcuttr
    western WA
    Made this for a Dirty Hand Tools 35 ton. Wouldn't know what to do for a Champion, shape of the wedge, fitting it up and all. I'm sure somebody makes one for your machine. Thanks for asking though. :handshake:
  4. Boogeyman
    Boogeyman
    Central Indiana
    I like the binford stamp on that wedge!
    dougand3, Chvymn99, eatonpcat and 6 others like this.
  5. metalcuttr
    metalcuttr
    western WA
    Sharp eyes there! Wondered if anyone would catch that.
  6. Mrxlh
    Mrxlh
    Dat Boot
    No need to heat treat it, just use the same upright piece split in 2 for the wings…
  7. Screwloose
    Screwloose
    Quenching won't do anything to the low carb steel but it could be undesirable for the weld metal.
  8. Eric Wanderweg
    Maybe a stress relief operation in the oven at 400 degrees for a couple hours would normalize everything…
    And maybe if he gets a raging fire going in his wood stove, throws half a bag of charcoal in there, then toss the wedge in, then wait a few hours for it to die down, he can get some carbon into the steel and raise the Rockwell a few points, or at least case harden it:whistle:
  9. RCBS
    RCBS
    Over here
    I tried to bust a cherry crotch by hand last year. I gave it about 40 haymaker shots with absolutely no result. Not even very large...maybe 18" or so. It was green but the splitter didn't care.
  10. metalcuttr
    metalcuttr
    western WA
    This was my thought. Bury the wedge in coals in the fire pit augmented with a leaf blower. At dull red I would water quench to cool. Even with a heating in a carbon rich environment, mild steel is still low carbon even with a slight case harden effect. I don't think there is a need to heat to full austenitic temps or temper afterward, because of the low carbon aspect. It is just a quicky home made wedge after all. If I really want to get fancy I'll get some L-6 tool steel (I may already have some) or some 4130 alloy. Maybe the best bet would be to just use thicker plate and change the horizontal blade design. Or I could just buy the 4 way that they make for this machine. :D
  11. metalcuttr
    metalcuttr
    western WA
    Chvymn99, eatonpcat and brenndatomu like this.
  12. chris
    chris
    SE WI
    Thicker plate would help . i used 1/2 stock also gave them about 15 deg up angle, back higher than front gives the split somewhere to climb a bit. I do not make them the full length of the main wedge and set them back a bit so that you do not have all three edges hitting at once. less initial stress on wedge and beam. my main wedge is only about 1" thick x 10" long and 10 " high. There is a spreader behind the main wedge, so I get more if a slicing action than brute force
    eatonpcat, brenndatomu and metalcuttr like this.
  13. Screwloose
    Screwloose
    At some point it would have to be quenched to harden. It would add a bit of carbon though.
  14. Scotty Overkill
    What if you annealed some leaf spring material and tempered it after fabrication and welding?
    eatonpcat, Screwloose and metalcuttr like this.
  15. metalcuttr
    metalcuttr
    western WA
    I am sure that would work. That would be 1095 steel? Only worries would be at the weld. So many ways to skin a cat. I heated with a rosebud tuned slightly rich then straightened the wings. Continued the heat then quenched. We will see how it goes. Any more problems I will remove the wings and use thicker shorter ones tilted slightly like chris said. Biggest thing is staying within a 4 way's capability!
