Homelite 5 ton hydraulic fluid?
Discussion in 'Chainsaws and Power Equipment' started by mattjm1017, Nov 30, 2013.
  1. mattjm1017
    mattjm1017
    Ive got one of the homelite 5 ton electric splitters and Im going to have to add some more fluid to it tomorrow. The dipstick has fallen off in the reservoir and iI lost a bit of fluid trying to get it out some Im going to just dump it all and try to get the stick back out my question is what kind of hydraulic fluid should I put back in? Ive lost the manual and the only thing Lowes had was AW-32 hydraulic oil the jug says it mixes safely with original fluids but before I dump this stuff in I just wanted to be sure that it would be good for the splitter.
  2. MasterMech
    http://manuals.homelite.com/documents/1615
    I'm surprised but the manual doesn't mention what type of fluid to use. Not that I saw anyways. AW32 is a good all-purpose fluid and should not present any compatibility issues. Universal Tractor Hydraulic fluid and automatic transmission fluid are also generally acceptable.
    WeldrDave and mattjm1017 like this.
  3. mattjm1017
    mattjm1017
    Thanks Master Mech I found a copy of the manual online and couldnt find anything about what type of oil to use. I just wanted to check cause I dont know anything about this stuff and would hate to screw it up with the wrong type of oil.
    MasterMech likes this.
  4. Oliver1655
    Oliver1655
    Central Missouri
    There is a standard "hydraulic jack" oil sold by the quart for use in bottle jacks. The AW-32 or 46 will work fine.
  5. clemsonfor
    I would just use transmission fluid if I don't have any hydro fluid around, for no more than you will need.
  6. mattjm1017
    mattjm1017
    The AW-32 seems to have worked just fine I drained out all of the fluid that was in the splitter and still couldnt find the dipstick:mad: I dont know what happened to it so I just kind of guessed at how much fluid to put in. The manual says it holds 3.7 quarts and I have a gallon jug of oil so I put around 3/4 of the jug in and it seems to be working fine. Thanks for the advice guys:thumbs:
  7. clemsonfor
    If u out 3/4 of the jug in your still about a half a qt low!! There is 4 qts to the gallon.
  8. mattjm1017
    mattjm1017
    Yeah I was guessing at it I meant to say I used a little over 3/4 of a gallon. It was all just rough guessing since I cant find the dipstick anywhere. I wonder what would happen if I put in to much?
  9. clemsonfor
    It will blow it out of the vent.
  10. mattjm1017
    mattjm1017
    That shouldnt be a problem then right it sounds like your saying it will just blow off the excess and sort of self regulate itself?
  11. clemsonfor
    Basically. I'm sure there is some technical reason but yes it will just push out the vent when the cylinder pushes the fluid out of it to the reservoir. My buddy overfilled his gas splitter and as he was using it with me it just flowed out of the vent. Yes u want air space in their but really I think it is so that it will not puke fluid everywhere. No one wants something that leaks all over the place so the fluid level is set for that.
    mattjm1017 likes this.
  12. Pallet Pete
    Pallet Pete Moderator
    Ovid
    clemsonfor likes this.
  13. Oliver1655
    Oliver1655
    Central Missouri
    The air space also allows for the oil to expand when it heats up.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
  15. mattjm1017
    mattjm1017
    raybonz likes this.
