Holy crap that's hot
Discussion in 'Chainsaws and Power Equipment' started by tg.weaver, Sep 7, 2017.
  1. tg.weaver
    tg.weaver
    Splitting wood tonight saw this any idea what or where I should begin...[​IMG][​IMG][​IMG][​IMG]
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Chvymn99, TurboDiesel and Eric VW like this.
  2. Eric VW
    Your last pic looks like you were trying to get away from a bomb....:startled:
    Is that the pump?
    I've never seen any part of a splitter glow like that:eek:
    I'll :popcorn: until someone else chimes in!
    Stay safe tg.weaver :yes:
  3. brenndatomu
    Whatzat? Muffler?
  4. tg.weaver
    tg.weaver
    It's the pipe that comes off the engine and goes for the muffler. The last pic was a mistake
  5. Eric VW
    Mistake or not, now I can see that it's going to the muffler....a hot pipe that is!
    Chvymn99 and Horkn like this.
  6. brenndatomu
    I've seen red hot exhaust on many engines when run hard at night...probably not a problem...
  7. Eric VW
    Change/increase in relative humidity affecting?
  8. brenndatomu
    Nah, just the no/low ambient light makes it so you can "see" the temperature of the exhaust manifold and/or pipe.
    Steel starts to glow at 900* or so...and combustion chamber temps run well above that, so...
    Ralphie Boy, Chvymn99, Horkn and 4 others like this.
  9. Eric VW
    Well dang Brendy....learnt me sumpin' new right cheer.
    Thanx, big D!:handshake:
  10. The Wood Wolverine
    I've had the muffler on my 394 glow (not quite that bright) while milling in the dark.
    p61 western, Chvymn99, Horkn and 2 others like this.
  11. Eric VW
    For rizzeal?
    That's just :loco: :crazy: to me!
  12. brenndatomu
    Dad had an old Ford diesel tractor when I was a kid...I liked riding with him at night because the exhaust manifold would glow red and it blew sparks straight up out of the muffler when it was working hard...easily amused I guess I was...
  13. tg.weaver
    tg.weaver
    No humidity here tonight
    Horkn and Eric VW like this.
  14. TurboDiesel
    Running full throttle for a long time will do that.
    I doubt there is a problem.
    Ralphie Boy, Chvymn99, Horkn and 3 others like this.
  15. The Wood Wolverine
    I never realized it was getting that hot till I had a job that took me into the evening when it started getting dark. Imagine 10 minute wide open cuts w/ a 50"b/c and I had to trim the log to fit my 48" mill!
    Duane(Pa), Chvymn99, Horkn and 2 others like this.
  16. Eric VW
    :saw::saw::saw::faint:
  17. Andyshine77
    Andyshine77
    Cincinnati, OH
    Yup totally normal, you just can't see that in the daylight.
    Sent from my LG-H871 using Tapatalk
    Chvymn99, Horkn and Eric VW like this.
  18. concretegrazer
    concretegrazer
    Southwest MO
    I have one that'll have a fire out the stack under full load at night. No wonder it eats mufflers.
  19. Chvymn99
    Probably not a problem.... if it has a spark arrestor just make sure it's clean...could clog up and cause a bit of a hot situation....
    concretegrazer and Eric VW like this.
  20. tg.weaver
    tg.weaver
    Think I have to worry about it exploding? I check oil level tonight after pulling the muffler it is low. No spark arrester that I found might order a new muffler only like 10 bucks. Thoughts
    Eric VW likes this.
