High Temperature Silicone Sealant
Discussion in 'The DIY Room' started by Kimberly, Feb 3, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I was told by the Selkirk guy to seal around the chimney where it exits the thimble with high temperature silicone sealant. What is the general exterior temperature of a Class A Stainless Steel Chimney in normal use? Do I need any special silicone caulk because I am seeing regular silicone caulk with maximum temperature ranges up to 204°C. The Rutland High Temperature Caulk only increases that to 260°C; it would appear that they are doing the "Lure to catch fishermen." I have yet to see any sort of high temperature sealant that can be used outdoors and remains flexible that is significantly higher in temperature than normal silicone sealant.
  2. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    I have been told to just use 100% silicone.
    wildwest and Eric VW like this.
  3. papadave
  4. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Stihl Livin, Eric VW and wildwest like this.
  5. brenndatomu
    Any red "high temp" silicone will work, 500-600*f IIRC
    Most hardwares or automotive parts stores will have it
    Eric VW, wildwest and papadave like this.
  6. papadave
    I can put my hand on Class in normal use...can't keep it there too long though.
  7. papadave
  8. papadave
  9. Kimberly
    Kimberly
    The Kangaroo State
    As I said, the Rutland is only 260°C; regular silicone is 204°C. I would have to travel 65 km to get the Rutland so may just as well use the local available silicone caulk.
  10. Kimberly
    Kimberly
    The Kangaroo State
    Yes, but those little tubes would mean buying many of them.
  11. Kimberly
    Kimberly
    The Kangaroo State
    Again, that is only a bit higher in temperature than what I can get at Lowe's Home Improvement. If the outside of the chimney is not going to be that hot; meaning over 204°C, then I can just go with regular silicone.
  12. papadave
    How much do you plan to put on?
    The Rutland is rated at 500 degrees.
    Use one of the other even higher rated ones if you don't think that little tube will be enough.
    Eric VW likes this.
  13. Kimberly
    Kimberly
    The Kangaroo State
    That handles up to 343°C, 139°C above regular caulk; however, it is also pricey and you have to have it shipped, so there is the shipping fees to add to the ~$18.00 cost.
  14. Eric VW
    I like the permatex personally.... I've used it on single wall pipe without deleterious effects to the seal it formed.
    I'm cereal.....aka serious.
    papadave likes this.
  15. papadave
    You can pretty much get any of the hi-temp stuff locally.
    Really.
    Go to an auto parts store.
    Oh, and don't skimp on your safety......you're almost done.
    Be safe.
    milleo, wildwest and Eric VW like this.
  16. Kimberly
    Kimberly
    The Kangaroo State
    I appreciate all the feedback. It appears that I can use the regular silicone caulk rated to 204°C without worries.
  17. brenndatomu
    I was lumping Lowes in the hardware category, not a great one, but...
    Eric VW likes this.
  18. Kimberly
    Kimberly
    The Kangaroo State
    I have to fill a gap around the outside of the chimney where the horizontal pipe meets the tee; have not measured the gap but I am thinking a cartridge in a caulking gun will be needed. Then there is the inside gap as well that needs to be filled.
  19. Kimberly
    Kimberly
    The Kangaroo State
    Yes, when it comes to hardware, Lowe's is dismal. It seems they are moving to everything in blister packs with limited selections. I could not even find the eyebolts they use to sell when I was working on my tractor carrier.
  20. Highbeam
    Highbeam
    When silicone fails from heat it doesn't burst into flames so this isn't really a safety issue but a maintenance issue.
    Red silicone looks dumb IMO, I would rather use black or grey RTV rated to 600 degrees F (we aint in Canada). On the outside of Class A, you should see any higher than 200 degreesF with any regularity so the silicone options from Lowes should be fine.
    I use regular GE2 100% silicone (available in grey or clear) on my class A pipes to seal the storm collar. No troubles.
