High & Low BTU Score
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jan 9, 2024.
  1. buZZsaw BRAD
    Pignut hickory and tulip poplar. Couple rounds of sassafras too. FBM find. He only had pics of the TP but said i could cut and take whatever wasnt tarped. Bigger remnants the other hoarders didnt take. IMG_4642.JPG IMG_4643.JPG IMG_4644.JPG IMG_4647.JPG IMG_4648.JPG IMG_4649.JPG Hickory sectioned up easily with the Isocore. Some short chunks for the smoker. Guy came home while i was working and commented that nobody wants the big logs. I smiled and said these arent that big. IMG_4645.JPG IMG_4646.JPG Took only the correct length (i didnt cut them) tulip poplar rounds. Finished in a light rain. Decent load. IMG_4651.JPG IMG_4652.JPG IMG_4653.JPG Ill go back for the white oak as they are nice and straight, but kinda buried so maybe a PITA to dig out. Now that i think of it i can use the TP shorts too.
  2. Skier76
    Skier76
    CT and SoVT
    TP….there’s a Beavis and Butthead joke in there somewhere!
    Nice score Brad!
    ThomH123, Timberdog, Dok440 and 10 others like this.
  3. rotorburn
    rotorburn
    Jersistan
    Not many guys would be out cutting in the weather we had yesterday, myself included. Although that hickory is worth the price of wet hands, I’d say
    Timberdog, Dok440, metalcuttr and 4 others like this.
  4. buZZsaw BRAD
    It was dry when i started and rain was rather light so i kept going. Those that see my posts know i dont like having it under loaded. :whistle:
  5. buZZsaw BRAD
    Got the hickory split and stacked today. Before and after stack pictures. IMG_4658.JPG IMG_4659.JPG The white oak should fill it out
  6. Chud
    Chud
    NC
    Where’s the splitter engine replacement thread? :binoculars:
    Dok440, brenndatomu and buZZsaw BRAD like this.
  7. buZZsaw BRAD
    LOL!!! I told buzz-saw to post one. His work.
    Dok440 and Chud like this.
  8. brenndatomu
    X2! :binoculars:
    Dok440 and buZZsaw BRAD like this.
  9. buzz-saw
    buzz-saw
    Ct.
    I have no evidence ( pictures). I'm not too good as a photojournalist.
    Swapped out the old Briggs for the HF Preditor , easy swap. Hydraulic oil & filter changed (it needed it bad and was low, 3 gallons out and almost 5 back in), removed the nail from the valve handle and installed a bolt with double nut so it won't vibrate loose ( I didn't have a pin like it originally had).
    Instructed the operator that oil changes are critical and must be done on a regular basis (much more regular than the previous motor had) with the first around the 5-hour mark.
    Going to find him an hour meter to install to help keep track.
    The old motor will be donated to my coworker for his 13-year-old son to play with.
    He is into minibikes, and go kart sort of things.
    Good for the kid and it gets repurposed instead of going directly to the scrap pile.
  10. Eckie
    Eckie
    What....you mean you're supposed to change the oil in a splitter? Guess I should think about that sometime
  11. The Wood Wolverine
    Solid wood get there Brad! Wish I could get some poplar like that. This primo RO is a pain to try and keep the house under 76. Keep having to go down and load 1-2 splits at a time.
    brenndatomu, MikeInMa, Eckie and 2 others like this.
  12. buZZsaw BRAD
    You want poplar? :faint: Whats the lowest btu stuff in your stacks? I know you like the primo stuff.
  13. The Wood Wolverine
    I have a little less than a cord BL and the 2.5 cord of HL from the monster, rest is all chestnut oak. Be nice to have some shoulder wood.
    EDIT; burning all the RO I have now, so there's probably a cord plus still in the basement.
  14. Chud
    Chud
    NC
    I will trade Poplar for plastic pallets!
  15. The Wood Wolverine
    Ha, deal!! I sure have enough. Meet you 1/2 way? :handshake:
  16. Chud
    Chud
    NC
    These are decent size logs, I will need to use my tractor to load you up. This way you can also get the pleasure of cutting them up.
  17. buZZsaw BRAD
    No market for the TP Chud? Use it yourself or does it get tossed?
  18. Chud
    Chud
    NC
    Nope it has a bad rep like pine. I have tons of it available just like pine.
  19. Wouldsplitter
    Wouldsplitter
    Illinois
    The only problem I have with hickory (other than being kinda stringy and taking 2 years to season) is that when you cut it the bark is so hard and brittle, that pieces fly off and hit you in the face like a rock. Every. Single. Time. . . Good btu's though. :thumbs:
  20. Moparguy
    Moparguy
    TN
    Nice. I know they're not big on btu's but I do wish we had more Sassafras around here. I hardly ever see them, and when I do, they're usually small or dead. I just think they're interesting trees. I would gladly replace all of the Boxelder with Sassafras.
    buZZsaw BRAD and Chud like this.
