What are you guys using for Hedge Trimmers? I don't want to spend $300 on a nice gas unit. I could add a hedge trimmer to the Kombi Unit, but it would be a trimmer on a pole....difficult to use.
Do you have electric available? There are good corded electric units that come with less cost of ownership than gas units but still have excellent quality blades. You can run one off a very small generator as well.
I know Stihl makes an electric for $149. Too rich for my blood. I think I will go electric though. Gas units are too costly.
The better hedge trimmers are double action. The top blade is going out as the bottom blade is coming in. I have a Stihl HS80-R-20 double action that I bought used for $75 and I have a Echo HC1500-2E, like new I bought for $100.
X2.. The better ones are double action. But for light use, the single blade moving works. I need to buy a Hedge trimmer here shortly. My Sand-cherries are out of control! I will probably go with a gas unit. The Stihl low end homeowners model (45) is supposed to be pretty good. But I will probably go with the (56 C-E).
I have a 30 year old Black and Decker electric, I bought new, I use round the house, light weight, nice to use, outback I use the gas ryobi, heavy and clumsy, but works best out there, gets the job done and can reach up high
The cheap electric units are not usually sharpenable. The blade assemblies are riveted together and not enough clearance to file the edges. When it ceases to cut well, toss it and repeat. If you have very little trimming to do, a pair of manual hedge clippers work very well.
For well under 300 you can get a mtd gas variant. I ran a weed Eater brand gas unit light commercial use and it held up surprisingly well for years. Iirc it was 150$ but that was years ago. I still have it but now run a 30" stihl just because I now do more business and speed matters. Gas is the way to go. I can trim your hedge before you have your cords unwound.
I use a 13 year old B&D electric that I picked up when I bought my house. I have 6 small bushes. It'll last me for as long as I need it. It's even sliced a couple extension cords and it keeps on going.
I wore out a couple B&D electrics and the blade wouldn't move any more. Then I had a Homelite for some 12-13 yrs and then got a new Weed Eater/Poulan hedge trimmer. They were both single action with the Weed Eater being noticeably better than the Homelite. The Homelite stationary blade was soft and I had to replace the blades after just a few years. Never any trouble with the replacement blades and never any trouble with the Weed Eater except replacing fuel lines once. Then I got the used Stihl HS81 and it was night and day better than the Weed Eater. Very productive and will cut anything you can get between the cutter teeth. The cutting action is very fast as both blades move. They don't make it anymore. I would have never bought it new as it costs too much. The used Echo I have is almost as good as the Stihl.
Now you guys made me go and put in an ebay bid on a combi-tool with the long hedge trimmer attachment. It takes me a solid 6 hours to trim all of ours, so I do it once although it really needs it twice or more. I convinced my wife, time = $$, so if I can swing a sweet deal used I'm in.
I can pick up the Kombi attachment new for $179 + tax. I think it will be hard to use such a long tool.
You won't regret it I do have a generic unit that I got as a package deal. It's an Extreme 4-n-1 unit. Comes with Hedge trimmer, pole saw, brush cutter, and line trimmer. It was $209 new last year. The hedge trimmer and the pole saw are what I use the most. Now that I have a Kombi KM 130 R. I will be buying the hedge trimming attachment and the pole saw. The generic one works, but the power head lacks the torque that the Stihl unit has. I just weed wacked around my pond yesterday for the 1st time with the Stihl. It used to take 1.5 hrs, 2 tanks of fuel, and 2 full heads of line. Yesterday it took about 40 min and I used the 3 blade (light brush) set up, then put the trimmer head back on and did the rest of my property. I still had almost 1/3 of a tank when finished and it didn't take me 1.5 hrs to do Everything. The hedge attachment comes in super handy when doing tall shrubs or bushes. If I had to use a hand held unit on my Sand Cherries? I would be on a ladder and need to tape a 4 foot extension to it.
Stihl just got a little more of my money today. Placed an order for their clippers. Should make quick work of my job.
I'm hoping its a lot easier than an 8' ladder, extension cord(s), and a whole lot of balancing on one leg while on the "not a step" step Tall arborvitaes, forsythia, and something that eclipses 10' near the house put my money on the PAS or Kombi. Definitely fall off the ladder yearly into whatever random shrub breaks my fall after my balancing act inevitably fails.
The hedge trimming heads rotate 180°. So they can conform to help you from any position. This will definitely aid in trimming 10' tall Arborvitae's and the like. The 4-n-1 Extreme unit works well, but my KM 130R has 3 times the amount of power. Mind you that is the largest of the Kombi units. They make one homeowners model (56??) Then they make the KM 90R, KM 110R, and the KM 130R. After running mine, I probably could have got away with the 90 or 110 But for the price difference, I went with the biggest one they had. It's definitely the most powerful trimmer I have ran. Period. . .
I have the KM56, which works well for my needs. The pole saw is great...just got a couple 12" chains for the 192. They may be the same loops as the pole saw runs....bonus! I'm really loving the blower. I used an electric and a push broom. Both didn't do anywhere near as well.
