Have some splitting to do now
Discussion in 'The Wood Pile' started by Greg, Apr 7, 2020.
  1. Greg
    Greg
    Nice load of pin oak
    217B74AA-9480-4D64-98EA-09A17B7255F9.jpeg 63B4F0B4-018B-489A-93FA-DB1C4873F6CD.jpeg B7111AF6-D94F-4EEC-AD25-F0258FBFC495.jpeg
    jrider, Cash Larue, Maykoppa and 20 others like this.
  2. MikeInMa
    It's nice to see that area you paved and stacked the concrete blocks, is working out for you.
  3. buZZsaw BRAD
  4. Greg
    Greg
    I don’t think so. I decided to just refill the lean to with dead ash, start burning 10/1 and burn the ash until holidays, then have the splitting party to refill with all oak so I can have full oak lean to by 1/1/21
    At least that’s my new plan. Lean to at 60% now
  5. buZZsaw BRAD
    if memory serves me correct, werent you pulling dead ash from woods nearby and a vast amount there???
  6. Greg
    Greg
    Yes, have racked everything direct to lean to from 4 wheeler cart. I have put in about 40 cart loads so far. Maybe need 40 or so more to fill it
  7. Greg
    Greg
    And I am still burning and plan to u til end of month, as I will have plenty of scraps and some gamey ash along the way
  8. buZZsaw BRAD
    A lot of it can almost go from stump to stove!. More or less the same around here with the ash. Some i cut yesterday had the bark stay on when i split it this morning.
  9. Haftacut
    Haftacut
    Rives Junction, MI
  10. Haftacut
    Haftacut
    Rives Junction, MI
    Top notch outfit you have there Greg! I always enjoy seeing what you have to post. Seems everything you do has a reason behind it:yes:
  11. Backwoods Savage
    Greg, I don't remember. What do you use to load the logs?
  12. Greg
    Greg
    Processed and rolled up, lean to at 2/3rds, ash to finish April
  13. Greg
    Greg
    That load, T190 with swivel grapple
    Other times a mini loader with grapple
  14. Horkn
    True. A lot of the dead ash is pretty much ready right away after being cut. Given a summer after split and stacked, and it's typically good to go even in an EPA stove.
    Greg
    If you typically split a few months before burning in the owb, that dead ash will probably be the best wood you've burnt.
  15. Wisconsin Woody
    Wisconsin Woody
    Cecil, WI
    But Ash wet or Ash Dry
    A king shall warm his slippers by...
  16. Horkn
    That same poem says that elm won't make you warm, or something to that effect. I'd take dry elm over wet ash any day, if I needed to burn it that season.:cool:
  17. NH mountain man
    NH mountain man
    WMNF N.H.
    Looking good Greg ! I look forward to your pics of your annual huge pile of logs and rounds. Take care, and work safe!
  18. Greg
    Greg
    Since about March 1st I have been cutting and throwing it in the same week, mostly of a size that doesn’t need split. There is just so much of it I have moved to that plan, does fine in OWB. And I’ll finish filling the lean to with it. That pile of wood is nearly all pin oak, and all pretty green and cut over the last year. It won’t hurt one bit to have it sit in that pile a year or two. So will keep building the pile with oak, some locust and the shed with ash
  19. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Nice setup!!! I would love to have that arrangement!!!!
  20. Wisconsin Woody
    Wisconsin Woody
    Cecil, WI
    Elm wood burns like a churchyard mould
    E'en the very flames are cold
    And it is a bitch to split!
    Chazsbetterhalf and Horkn like this.
