Hauling saws - Truck bed
Discussion in 'Chainsaws and Power Equipment' started by RCBS, Dec 19, 2025.
  1. RCBS
    RCBS
    Over here
    For a long time I never had any issues with hauling my saws in a truck bed. I usually try to put them up against the tailgate sideways and secure with a bungee. I run into a problem a while back with having too much/many saws for that method. Two saws with 24s and a third make it impossible. I'm not a fan of them having a Monday night raw match back there while I'm driving around. How do you keep yours secured while in transport? I'm thinking of making some sort of jig from lumber.
  2. Chud
    Chud
    NC
    I have a rubber bed mat in my Tacoma that keeps my saws from sliding around. There’s typically rope bags and other things to wedge them up too.
  3. theburtman
    theburtman
    I have a 4x4 cut to the length between sides of the truck bed(actually just a little short ) and place it behind the wheel wells. I then can put saws, gas cans or whatever between the 4x4 and the tailgate.
  4. MikeInMa
    From the interweb.
  5. RCBS
    RCBS
    Over here
    Yep, this is where I was going with it. Not real friendly to the buck n stuff hoarding but I rarely if ever do that. When I do I just make a cubby in the wood for the saw/s.
  6. RCBS
    RCBS
    Over here
    I've been doing this to get by.
  7. T.Jeff Veal
    I need to build something for our F250, currently we have a big piece of OSB board the saws sit on, with a strap thru the handles so they don't slide around.
  8. isaaccarlson
    isaaccarlson
    Colfax, WI
    If I’m hauling wood, I’m not hauling more than 2 saws.
    If I’m hauling more than 2 saws, I’m probably not hauling wood.
    I set mine on the floor or against the back of the cab. I will stick the bar down between wood rows if I’m full.
  9. John D
    John D
    Syracuse ny
  10. The Wood Wolverine
    My plastic bed liner has slots for 2x's(as shown in Mike's pic). I have a piece cut for the rear most slot and load my saws E/W and they don't move much at all.
  11. buZZsaw BRAD
    X2
  12. buZZsaw BRAD
    Normally if im taking two saws to a cut ill interlock the bars with the side of the handles to lock them together.
    When the PU is full of wood ill cram them in the cab. or slide a bar vertical in the bed somewhere. I have bungeed in the past and always have them at my disposal.
  13. isaaccarlson
    isaaccarlson
    Colfax, WI
    I only do this if they have scabbards. Works well.
  14. buZZsaw BRAD
    They do.
  15. Ohio dave
    Ohio dave
    Akron, OH
    I cut a IBC tote liner in half at 45*. I put the saws, fuel, pipe and other supplies in that. I got the idea from Sams Doing Stuff on YouTube.
  16. eatonpcat
    You're not driving fast enough!!
  17. KSPlainsman
    KSPlainsman
    Kansas
    This is what I came up with. It only holds 2, the way I made it, but I don't see why it couldn't be expanded on. I don't drive fast, but I like being able to see my saws while driving down the road. Also, I wanted a setup that doesn't risk a piece of wood falling, or shifting around and banging up the plastic, or any other part of my saws. This gives me a nice little cubby below it for either wood, or other tools, gas cans, or whatever I'd want to haul.
  18. T.Jeff Veal
    That looks good.
  19. KSPlainsman
    KSPlainsman
    Kansas
    Thank you, Sir. It does the job.
  20. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Same here:D
