Hastings stove or Barefoot Pellets?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Feb 1, 2016.
  1. BHags
    BHags
    Massachusetts
    My Hastings stove is 9 yrs old. I take good care of it, tear it down and clean each season, and replace parts as needed. This year started well, but recently the glass got dark, and clinks formed in the burn pot. I switched out the exhaust motor and gasket last year, it has a new door gasket, and the pipe is clean. I cleaned it again yesterday, pounding the hell out of the back wall with a wooden mallet, and getting a lot of ash to fall. After I vacuumed and started it back up, it seemed to be burning well, and the glass stayed clean. at the end of the day, I shut it down and still found clinks. Barefoot pellets maybe? I have used them in the past without a problem.
  2. will711
    will711
    Pocono Mts.
    Welcome to the show BHags :handshake: It might be the Barefoot ,this years batch formed some cakey ash in my burn pot and I think a few other folks here have had some issues too.
  3. BHags
    BHags
    Massachusetts
    Thanks. Good to know, although I was hoping it was a simple stove fix. I'm sitting on 3 more tons of Barefoot!
  4. will711
    will711
    Pocono Mts.
    Why don't you try a few different brands of pellets and see if you get the same issue , if not then maybe it is the pellet ,if you do maybe it's an issue with the stove .
  5. ivanhoe
    ivanhoe
    Northern Ontario
    Welcome to the FHC BHags :handshake:
    I agree with Will on being the pellets, try a few bags of another brand:yes:
    ttdberg and IHATEPROPANE like this.
  6. will711
    will711
    Pocono Mts.
  7. BHags
    BHags
    Massachusetts
    I think I have a bag left over from last year. When the hopper is empty, I'll reload. Thanks guys.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Welcome fellow hastings owner :handshake:. I've only had mine since last fall so i don't have a ton of advice to offer. But i do know mine isn't very picky. Only pellets that tend to cake up on me are prestos but they still burn hot. I haven't burned any barefoots.
  9. BHags
    BHags
    Massachusetts
    ttdberg, ivanhoe and IHATEPROPANE like this.
  10. will711
    will711
    Pocono Mts.
    I know nothing about your stove if you can adjust the air it maybe worth a shot to try .
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Welcome to the forum! Like Will, I had the same issue with the Barefoot. I did get the sample bags from him but had the same results.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Or in the alternative a little less fuel, if you have any burn pot air bypasses you may not be able to control either in a manner that corrects the issue which is an improper air/fuel ratio unless the pellets are totally messed up.
    ttdberg, ivanhoe, BHags and 2 others like this.
  13. BHags
    BHags
    Massachusetts
    OK. I just ran a brand of pellets I used last year. The ash build up, clinks, while not quite as bad, still exist. I'm at a loss to why the stove just suddenly stopped working well. All fans are running. pipe is clear, nothing has changed since the beginning of the season, when it was burning fine.
    ttdberg and ivanhoe like this.
  14. krooser
    krooser
    Waupaca, WI
    Do you use a leaf blower to clean out the vent? A partially blocked vent or plugged stove may be your airflow problem
  15. BHags
    BHags
    Massachusetts
    Funny you say that. I'm on my way out right now to try it! I'll let you know.
  16. BHags
    BHags
    Massachusetts
    I'm not gonna lie...the leafblower thing was friggin cool! The back of my house and half of the house next door is covered in ash, but... The flame looks sharp and bright, we'll see what happens.
    343amc, PelletHound, ttdberg and 8 others like this.
  17. eatonpcat
    Sounds like you may have found the problem
  18. bogieb
    How many ash covers did you remove during your previous cleaning? And did you ream out that cavity between two of them real good (either with a suction hose or bottle washer)? If your answer was none, or that you didn't get the reaming tool so you could see the other end out the opposite ash door, that was the issue and the LBT got to all that crud back there.
    ttdberg, ivanhoe, BHags and 1 other person like this.
  19. krooser
    krooser
    Waupaca, WI
    Ash covered neighbor's house is never a problem...
    PelletHound, ttdberg, ivanhoe and 5 others like this.
  20. BHags
    BHags
    Massachusetts
    I pulled off the ash cover cleanouts. I pushed wire into every access hole available. I vacuumed every where possible. I pounded with a wooden mallet. And still the leafblower thing brought out what looked liked a lot of ash. I'll let it burn out and check the results.
