handles for 2 man saw
Discussion in 'Axes, Mauls, and Hand Saws' started by RJames, Jun 29, 2015.
  1. RJames
    RJames
    Anyone make or know where to buy handles for a saw blade like the one in the FHC logo? Got one hanging in the barn minus handles and I'd like to restore it.
    Thanks for any leads.
    Shawn Curry likes this.
  2. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    If you can't source them locally, I could probably help you. I do all sorts of custom wood working and wood turning. I would just need dimensions, length and diameter.
    I can finish them to make them look old too.
  3. Oldman47
    Oldman47
    Illinois
    The handles on a misery whip are usually simple straight round items. Simply turn a handle to a reasonable size for a person's hand, cut a thin slot for the saw blade to go through and drill a couple of holes for the bolts that hold the handle to the blade. With the blade in hand this should be easily done in an afternoon. You must have the blade in hand to get the slot the right thickness, basically a hand saw kerf width will be close. The spacing of the bolts that hold the handles on must also match, be fitted to, the saw blade.
    RJames likes this.
  4. unclefess
    unclefess Guest
    highland woodworking has them item #454632 11.99 a set
    RJames likes this.
  5. chris
    chris
    SE WI
    Another source, Cross Cut Saw Co
    RJames likes this.
  6. hiptfarms
    hiptfarms
    Fairfield County, SC
    Lehman ' s in Kidron, Ohio. They have a website.
