Handheld propane torch
Discussion in 'Chainsaws and Power Equipment' started by Eckie, Jan 25, 2023.
  1. Eckie
    Eckie
    I have a handheld propane torch head that goes on the little green bottles. I have used it for various tasks around the house, and have recently used it for starting the wood stove. Most times when I use it, it will run for about 10-20 seconds, and then the fire will go out, but gas still seems to be flowing. It usually will not reignite unless I turn the gas off (and that seems to be a slow stoppage even when all the way clised), wait 5-10 seconds and then start again. A few times the metal "tube" has had frost on it. I would think this torch should run for longer without issues. Is this normal, or what am I doing wrong?
    I will try to remember to post a pic later when I can of the torch.
  2. lukem
    Sounds like too much gas is flowing.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    Sounds like an outta the box defect. Made it China by chance?
  4. Eckie
    Eckie
    Hmmm....I usually open it all the way. I will try differently next time
    More than likely... Not sure if it's marked, or if I still have the packaging laying around.
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    It was more of a rhetorical question/joke. Almost everything mass produced, now a days, has poor quality control. The product usually has a warranty and the manufacturers take full advantage of the fact you can be the quality control person.
    Hopefully adjusting the fuel flow will alleviate your problems.
  6. Eric VW
    This. You can get close to wide open, but not completely.
    And don’t get the torch too close when your kindling has started to flame. Hold it back a few inches. Otherwise the kindling fire will snuff your torch flame. This happens even with a piezo assisted torch head on either the green propane bottle or a MAPP bottle (yellow canister).
    JB Sawman, T.Jeff Veal, Horkn and 2 others like this.
  7. brenndatomu
    How old is the bottle? My first thought was its almost out of gas...
    JB Sawman, T.Jeff Veal, Horkn and 3 others like this.
  8. clemsonfor
    When it was cold like below freezing mine wouldn't half work..I took it to be maybe ice was forming in the thing and blocking it up?
    I only open mine all the way if I am starting a fire. For other things I barely have it cracked open.
  9. clemsonfor
    Here is a question I have. I see on the internet it says there a different torch head. But my question is can I use my cheap propane torch head I bought at Walmart on a MAPP gas bottle? Will It Work correctly or at all?
  10. brenndatomu
    No
  11. clemsonfor
    Simple and precise answer!
  12. KSPlainsman
    KSPlainsman
    Kansas
    Some are rated for MAPP gas, some are not.
  13. KSPlainsman
    KSPlainsman
    Kansas
    I once had a large propane bottle, that when full, first hooked up, it was always a low flame on my grill. (I know, a bit different but) Once I'd unhook it, then rehook it, it'd work fine. Maybe it'll sound silly, but try removing it, then putting it back together . Maybe something is just out of whack.
  14. TurboDiesel
    Are you turning the tank upside down?
    Propane has liquid in it. Turning it upside down could let liquid out.
    Are you (re)filling these propane bottles?
  15. Screwloose
    Screwloose
    You need to open the valve the first time slowly or the rush filling of the hose will trip the safety valve and restrict flow.
  16. KSPlainsman
    KSPlainsman
    Kansas
    Ah, thanks.......I didn't know that. I had 2 20lb tanks and it only did it on one. So I didn't know what was going on. Appreciate the info!
  17. Eckie
    Eckie
    It's a fairly new bottle, I've only used it a couple times. And it's never run very long due to the torch issues....
    So, I am definitely turning it, but more sideways, I don't think upside down. I will pay more attention to the angle next time. And not refilling...this bottle was straight from the store.
    If I get a chance, I'll take it outside tomorrow after work and try only opening it a bit, and the angle thing.
  18. Horkn
    I've seen that several times on my gas grill with 20 lb propane tanks, when when full. I do the empty to fill tank trade in, so I think this is simply bad valves. Never had this issue before the new safety valve we s were implemented.
  19. Horkn
    Ahhh. Makes sense.
    I never knew that either. Stupid safety valves.
    Thanks Screwloose !
    Funny that I never heard about this in all of the "king of the hill" episodes I've watched. 1b160bfa-4f6c-4798-b56a-43d73f0b7cbb_text.gif
  20. Mrxlh
    Mrxlh
    Oklahoma
    Your regulator is bad…
    KSPlainsman and JB Sawman like this.
