Guess the saw weight
Discussion in 'The Wood Pile' started by jrider, May 12, 2022.
  1. jrider
    jrider
    We have a lot of guess the log weight posts so I figured I’d switch it up. The other day I had to put the 36” bar on my Husky 390. It felt considerably heavier than my normal 24” bar so I decided to weigh both scenarios. I made sure to fill the gas and bar oil for each weighing. The bars are both standard Oregon bars. So without looking up specs, who wants to guess the weight of each saw/bar and chain combo?
  2. buZZsaw BRAD
    24lbs fully fueled and 36 bar
  3. Sawdust Man
    Sawdust Man
    25lbs with the 36" setup, and 23lbs with the 24"
  4. PatrickNY
    PatrickNY
    Putnam County, NY
    26# w 36" bar
    22# w 24" bar
  5. Canadian border VT
    22.5 w 24”
    24. W 36”
  6. jrider
    jrider
    Lot of good guesses so far. I will say, I was surprised at how small the difference is between the two. I would have personally guessed there would be a bigger gap
  7. buZZsaw BRAD
    The rare occasion i use the 36 bar i notice how nose heavy the saw is. If i used a longer bar saw for multiple tanks of gas in a cutting session, i would invest in light weight bars. Two of my saw came with light weight bars...12" on my 201tc, and 25" Tsumura on the 400 which i swap around to the other saws.
    Are the bars lightweight Joe? For someone who runs saws as much as you do im surprised you dont have them.
  8. huskihl
    huskihl
  9. jrider
    jrider
    Nope, they are standard Oregon bars
  10. jrider
    jrider
    For which?
  11. T.Jeff Veal
    19.5# 36"
    18.6# 24"
  12. huskihl
    huskihl
    36 on the 390
    amateur cutter and T.Jeff Veal like this.
  13. Andyshine77
    Andyshine77
    Cincinnati, OH
    19 lb 10 oz with the 36
    19 dead nuts with the 24
    All I use now are reduce weight bars, they make a substantial difference.
  14. jrider
    jrider
    Full 390 with 24” standard oregon bar is 22.5 pounds while the saw with 36” standard oregon bar is 25. I would have guessed it was more than a 2.5 pound difference. The saw feels much heavier with the longer bar but probably because it’s nose heavy and not as balanced.
