Grappler on the way!
Discussion in 'Chainsaws and Power Equipment' started by Sourwood, Oct 28, 2022.
  1. Sourwood
    Sourwood
    Popcorn, IN
    worried about if my timber clear cutting causing cleanup and brush issued getting over my head, I bit the bullet
    my tractor dealer has the grapple on hand, but had to order the Third Function control.
    I expect it will be the same as when you install a loader- always glad you bought it once you start using it.
    That guy Tractor Mike on y-tube mentioned his dealership sold a bunch after a huge storm in his area. He figured a lot would turn up on market place and Craiglist, after everyone cleaned up their messes. Never saw them. Assumes the buyers found how handy they are and kept them.
    Ah well, that is just that much less from the timber sales that I have to pay taxes on.
  2. T.Jeff Veal
    You will love it, especially for cleaning up tops and brush. Unless we're bucking logs on the woodyard or moving pallets/totes with the forks, our grapple stays on the tractor
  3. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    You will love it!!!!!! 121305D7-BB74-43B6-8500-585379E149D0.jpeg F7293611-06CF-445E-AE5E-A8BA60DEF697.jpeg
    Gasifier, HoneyFuzz, Sourwood and 8 others like this.
  4. Wishlist
    Wishlist
    Corunna
    Use mine all the time , great tool that has many uses .
    Stinny, Gasifier, HoneyFuzz and 4 others like this.
  5. Wingshooter
    Wingshooter
    west Mansfield ohio
    I have a root rake / grapple for my T590 and they're awesome.
  6. buzz-saw
    buzz-saw
    Ct.
    Well worth the investment!
  7. sirbuildalot
    sirbuildalot
    Mass
    Not only are grapples great for logs and brush, but they also work quite well for many other jobs....like building a retaining wall with 1,000+ lb. boulders.
    Stinny, HoneyFuzz, fuelrod and 2 others like this.
  8. Stinny
    You're gonna wonder how you ever got by without it Sourwood ...
    Gasifier, HoneyFuzz, GrJfer and 5 others like this.
  9. Screwloose
    Screwloose
    You will NOT regret it!
    Actually they are kind of fun to use and handy for other things.
    Removed a fence for one friend, rocks for another.
    Pulled my well pump......
  10. MasterMech
    Galvanized pipe? If so, that is indeed a heavy pull...
    HoneyFuzz, Screwloose and T.Jeff Veal like this.
  11. Screwloose
    Screwloose
    Yes it was, grapples like chain link fence!
    HoneyFuzz, T.Jeff Veal and MasterMech like this.
  12. MasterMech
    Gasifier, JD Guy, HoneyFuzz and 3 others like this.
  13. Sourwood
    Sourwood
    Popcorn, IN
    Sirchopsalot Woodsnwoods Screwloose Question. The unit in stock is slightly longer than another that sells well. It could be a few weeks bofore he gets more. He said the grapple in stock weighs 150 lbs more.
    amy i giving up a it of lift capacity? Should i get the narrower unit? I think. Its six feet and the in stock is a few inches wider
  14. MasterMech
    You have the 911X loader?
  15. Sourwood
    Sourwood
    Popcorn, IN
    I am not sure what that is. I have a Massey 60 hp
    buzz-saw, T.Jeff Veal and Screwloose like this.
  16. buzz-saw
    buzz-saw
    Ct.
    Thats a decent size tractor isn't it.
    I have a small Massey 1723 series and put a grapple on it and have zero issues.
    Sure it takes some of the lifting capacity just like everything else you put on it. Max Capacity; minus the weight of the implement gives you the weight of what it could lift.
    I think mine weighs around 250 lbs
    HoneyFuzz, T.Jeff Veal and Screwloose like this.
  17. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I agree with the others. You will wonder how you ever got along without it . So many uses beyond wood ! Like steel beams lol
    20221014_112148.jpg 20221014_110500.jpg 20221014_101639.jpg 20210628_134524.jpg 20210628_134531.jpg
  18. MasterMech
    Your profile signature said Massey 2605, of which, the popular loader choice is the 911X. 60HP is a fair shake bigger than a 2605 though. The 2605 is like 30-35 hp.
    T.Jeff Veal and HoneyFuzz like this.
  19. MasterMech
  20. Sourwood
    Sourwood
    Popcorn, IN
    We brought home the tractor with its new grapple. Done a little cleanup around some treetops i have already been cutting on. Getting used to maneuvering, and the weight differential.
    tomorrow i will hit the log yard.
    Also bought a new Stihl MS271 as a backup, and one of those Harbor Freight hatchets that has good reviews.
    billb3, brenndatomu, Stinny and 5 others like this.
