Gooseneck trailer question
Discussion in 'Everything Else (off topic)' started by VOLKEVIN, Dec 27, 2017.
  1. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    I need the knowledge base of the Forum- I have a Ford Super Duty that has a 6" lift and 37" tires. My truck bed is 44" high. I want to get a 20' gooseneck trailer with 2' dovetail. I hooked up one and although I could attach the trailer, the front of the trailer deck sat 9" higher than the rear of the trailer deck which is not optimal.
    Does anyone know of manufacturers that make a taller gooseneck standard, or if there is a manufacturer that would not be opposed to doing about an 8" extra rise on a trailer?
    eatonpcat likes this.
  2. eatonpcat
    Can't answer your question, but your truck sounds Badazz!
    VOLKEVIN likes this.
  3. VOLKEVIN
    VOLKEVIN
    Thanks! It was kind of funny at the trailer dealer- the sales dude said that I need to lower the truck and the trailer would fit just fine.....ummmm, no. :salute:
  4. TurboDiesel
    I think Greg has a gooseneck
    Greg and eatonpcat like this.
  5. mdavlee
    mdavlee
    I had to raise the neck on the Delta 20+5 dual tandem to keep from hitting my bed on the new 2017 F250 with stock tires. If I remember right PJ trailers or Gator has a higher neck than delta. Make sure there's enough room to be able to turn and break over without putting dents in the bed rails. The cattle trailers we have are a pain for me to use. I have to pull the tailgate and be perfectly straight to get into my driveway. The neck of them drops down into the bed about 2" breaking over the top of the driveway
    MasterMech and eatonpcat like this.
  6. VOLKEVIN
    VOLKEVIN
    How did you raise the neck? I really liked the Better Built trailer I saw, and if I could raise the neck I would buy it.
  7. mdavlee
    mdavlee
    Adjustable neck. It sets about 6" difference front to rear. It levels out more when loaded pretty heavy. Trailer weighs 5500 lbs or so.
    Your tires are around 3.5" taller than the stock 18s. I would imagine you could order one. That may be what I end up doing with a stock trailer.
  8. huskihl
    huskihl
    Should have an adjustable height right at the hitch
    eatonpcat and mdavlee like this.
  9. huskihl
    huskihl
    And if you'e gonna pull a gooseneck around, you better start calling it a beavertail. :cheers:
    MasterMech, eatonpcat and mdavlee like this.
  10. TurboDiesel
    :confused:
    Must be a Michigan thing
  11. huskihl
    huskihl
    Not sure. Always thought that noobs called them dovetails, confusing the term with a popular woodworking joint. Been around excavating for 40 years and they'e always been called beavertails. I suppose Michigan could be wrong lol. Not the 1st time
    eatonpcat and TurboDiesel like this.
  12. VOLKEVIN
    VOLKEVIN
    I gotcha- yeah, the one I saw had the adjustable height front too; and after full adjustment I had the 9" difference from front to back of trailer. The rise of the main frame height bars are what needs to be higher, before the neck-
    Camber likes this.
  13. VOLKEVIN
    VOLKEVIN
    I'd heard both terms, figured they were just interchangeable.
  14. mdavlee
    mdavlee
    How heavy of loafs do you plan on having on It? You need probably 3-5" for squat to level out anyway. You may be able to have them build what you need at a factory instead of having to do it yourself.
    Camber and huskihl like this.
  15. VOLKEVIN
    VOLKEVIN
    I was going for a 14,000 lb trailer, and the heaviest loads would be round bales of hay- 12 to 14 bales at a time. Trailer weighs about 2,500 and the hay would max out the load capacity. The trailer guys said they would inquire about the factory building one custom for me, and that's why I wanted to check in with folks here first to see if there is a brand that does it stock. The word "custom" usually translates to "dig deep into your pockets," LOL!
  16. huskihl
    huskihl
    Is your hitch down under the bed? Or on a 5th wheel style gooseneck adapter?
    concretegrazer and Camber like this.
  17. VOLKEVIN
    VOLKEVIN
    It's the one down in the bed. I got the Reese ball, which sits about an inch lower than others, too.
    eatonpcat, Camber and huskihl like this.
  18. huskihl
    huskihl
    Nice. I thought maybe it was the other style and maybe an easy fix.
    Not sure if any brands typically fit a taller truck.
    VOLKEVIN and Camber like this.
  19. Greg
    Greg
    Yep
    I love it, especially the drop sides and dump features
    eatonpcat, Camber and TurboDiesel like this.
  20. Camber
    Camber
    Montana
    Try big tex trailers. I remember a young fella here who put a bunch of lifty stuff on his truck. His beaver tail was about an inch off the ground! They customized his, but it was a long wait. I remember him telling me that their engineering dept, had to get involved. (DOT):hair:
