Friends Fireview 'emergency'
Discussion in 'Modern EPA Stoves and Fireplaces' started by Eckie, Dec 16, 2023.
  1. Eckie
    Eckie
    My buddy called this am. His inlaws have been living with them for about 6-8 months, that's a whole different conversation. Anyway, he says he needs to call WS cause he needs some emergency parts. He can't talk much at the time cause of ppl nearby, but says the fil overfired the stove yesterday while they were gone. Below is the pic of the hole.
    I told him I doubt WS is open being a Saturday. He just told me he called and left a message. Do yall see a safety issue running the stove like this? It's his only heat, he's planning on running it, but knows he'll have to watch it extra since that hole leads straight to the cat....
  2. Eckie
    Eckie
    Another pic he sent...
  3. spotted owl
    spotted owl
    PNW
    Not knowing much about these particular stoves, can the cat be pulled and used as an old style “smoke dragon”? If needed find something(steel, fire brick, a welded stack of soup can tops) to put on that hole from the top to cover for a temp fix. Being an only heat source, get creative and keep everyone but him and his Mrs. away from the stove. Get the in-laws each, watch caps, hoodies and mittens.
    Owl
    blacktail, Screwloose, Chaz and 4 others like this.
  4. Ohio
    Not Ohio
    He could probably take the cat out and run it without it for an emergency. It would certainly be a better option than freezing to death.
    It looks like the scoop was damaged. Either the camera angle is weird or something else is going on because my scoop has two posts and cotter pins that hold it in place. See pic below. I have a fireview 205, so I am not sure if he has an earlier model.
    My understanding is the air scoop protects the cat and causes turbulence when the air goes through the screen portion of the scoop. Turbulence enables more of the wood smoke to come into contact with more of the surface area in the honeycomb cells.
  5. yooperdave
  6. brenndatomu
    I doubt that was totally from the FIL, but he very well may have finished it off.
    I think I'd find some stainless steel sheet metal, cut out a piece for each side of the hole, then drill a hole through each piece, use a small stainless bolt through the drilled hole to hold one piece of metal on each side of the hole to more or less plug it up.
    You could use plain steel too, but it won't hold up as well or as long.
    Brad M, yooperdave, Chaz and 8 others like this.
  7. Eckie
    Eckie
    I don't remember him saying what year his is, but it's older. He got it out of PA, had been wrongly installed in a house and never used....and I think he said he's been using it about 6 years.
  8. Eckie
    Eckie
    So I know he said it got hot last season, cause the metal piece was bowed some. Not sure if the inlaws were here at the end of the heating season, or if it was his better half. We were over there one night last week, and the stove was rollin fine rhat night. He said he could tell by the way it was burning when he got home last night that something was going on.
    I will pass on yalls suggestions. I'm sure he's going to order the parts as soon as he can get ahold of someone Monday morning. So anything he does will be temporary, hopefully they have the parts in stock.
  9. Backwoods Savage
    Oh boy, that must have been overfired more than once.
    Yes, get hold of Woodstock but don't stop at leaving a message. I would call again Monday morning. It may also be good to send pictures and you can do that via email. Let me know if you need the address.
    It could be used without the cat but one would need to be careful and watch it closely so as not to over fire it again. If in doubt, don't fire it up until it has been fixed.
    Along with the repairs, it looks like the firebox could use some sealing and check all gaskets.
    Ohio, yes, that is an older model but Woodstock can send an upgrade and it will look like yours then.
    Ohio, Chaz, Eckie and 1 other person like this.
  10. Eckie
    Eckie
    He will definitely be ringing them up in the am. He communicated with them a lot when he got the stove....they told him the year and changed that stove over to his name, so they should be able to get straight. I think he was already going to order gaskets, and maybe another cat....
  11. Todd
    Todd
    NW WIS
    That looks like the older cast iron scoop. I had one on my Fireview 205 back in the day. He should be able to order the new s/s scoop and cat heat shield. Probably needs a new cat as well.
  12. Ohio
    Not Ohio
    Their website says the cats are back ordered, he can still ask if they have any or AM recommendations. I would recommend to them having a spare on hand after two years of use. They last approximately 12,000 to 14,000 hours. I’m in my third year and have one stashed in the closest for when the one in the stove fails. The Woodstock cats are normally in stock in the summer. I also have a spare gasket kit for the fireview. It never hurts to be over prepared.
  13. Eckie
    Eckie
    Yesterday am I copied and pasted the responses yall had provided to my buddy in an email. He responded to me that he thought he had the new design.... Ohio s pic didn't go through. So I downloaded it and texted it to him while ago, he was like oh wow. So I'm sure he'll be asking them more questions in a bit....
  14. Ohio
    Not Ohio
    Had I known you were going to send him pictures of the firebox I would have cleaned out the ashes.
  15. Eckie
    Eckie
    He's got a hole in his...he won't judge! :rofl: :lol::rofl: :lol:
  16. Flamestead
    Flamestead
    Windsor County, VT
    Woodstock parts tend to be quite reasonable. I haven’t been into a Fireview, but have worked on a Keystone and have been deep into my PH. They also provide pretty decent instructions for replacing common parts.
    edit: sometimes the parts come with gaskets pre-cut and taped in place so you have a better idea on the assembly.
  17. Hoytman
    Hoytman
    OH
    Just another reason to love Woodstock Soapstone Stove Company.
  18. Oldhippie
    Oldhippie
    Ashby Ma
    Here's a place for an after market cat, it is a 2 squares and you need the surrounding frame and gasket material. The frame you need to get from WS but they sell the right size/length gasket material. I've got one on year #6. Still heating very well. It's ceramic.
    Woodstock Soapstone
  19. moresnow
    moresnow
    Stove requires 2 correct?
    brenndatomu likes this.
  20. Oldhippie
    Oldhippie
    Ashby Ma
    Yes you need 2 of the square cats, they fit side by side in the frame, which is not sold by them. But they give just the right gasket with the kit. I think they need the ACI-23 if it is the older Fireview.
    In 2018 it cost me $204 for the 2 combusters and the gasket kit.
    I wouldn't be hesitant to go with this product as long as you can use a frame from one of the newer stoves. Mine is still working very well at 5 full years and it will most likely complete this year. I like it as I don't need to do the 50/50 vinegar/distilled water thing. I just gently tap the dust out once or twice a season and then brush off the protective screen around the cat.
    moresnow and brenndatomu like this.
