For those that burn White Pine.
Discussion in 'The Wood Pile' started by BeechNut, Jun 28, 2018.
  1. BeechNut
    BeechNut
    Pennsylvania
    I have a few questions. If I want to be I can be swimming in white pine, basically out my backdoor. A guy that has a camp behind my house is getting 3 monsters takin down. I mean monsters. They have the huge arms growing off the main shoot. All free if I want it. I have plenty of room to stack it. I've never burned pine before. If I wanted to could I burn nothing but it for an entire season. I hate to not get it. Would I be correct in assuming I would burn double what I normally do using nothing but pine. It would be nice to sneak in a year of this free pine and give all my oak an extra year to get even better down the road.
  2. brenndatomu
    Double...yeah that's probably about right. Still needs to dry a year or so though. That's where Pine gets its bad rap, just because you can burn it green, doesn't mean you should!
  3. BeechNut
    BeechNut
    Pennsylvania
    I wouldn't touch it for at least 2-3 years and then I could let a seasons worth of white oak get another year on it. I can't fathom not taking all this wood!
  4. Breechlock1
    Breechlock1
    I burn pine. Its nice saving hard woods and getting stuff to dry longer. I usually only use it during shoulder season, make kindling, and to burn up coals left by honey locust. I get a lot of ponderosa pine as my neighbor a few doors down has an old row of them that his grandmother planted (he is 70ish) that are slowing dying. I take a few down every year for him.
  5. billb3
    I burn some.
    I let it season for a year though.
    It's my first fire every morning as it gets the stove and room up to temp quick. On a warm day that might be my only fire until after the sun goes down. On a colder day if I have nothing better to do I'll stuff the stove every two hours with pine. If I have better things to do then maple or oak goes in.
    I used about a cord last Winter and two cords of oak. With a smaller stove sometimes we get coal build up from the oak and will have some pine fires on top of them to keep the stove temp up and give the coals time to finish burning.
    I've got a bunch of pine trees down from storms last Winter . About a cord stacked up so far. Some still in logs for slabbing. Most are only half down and still alive so they can stay that way for now or until I get to them.
  6. amateur cutter
    I too will burn Pine happily. That close & free you can't really go wrong. It heats quick, burns coals down well, saves hard wood for cold weather etc. A good stove will burn Pine pretty effectively. Burn it on weekends/shoulder season as was stated. Save a good bit of hardwood.
  7. tamarack
    tamarack
    paulina oregon
    Make sure it's dry! We have a bit of Idaho white pine here where I live, but most of the pine is ponderosa. Pretty good stuff if it's standing dead and no twist. Great shoulder wood.
  8. papadave
    Yep, I burn Pine after it's dry (same as any other wood). Plenty of folks have nothing but Pine and get by just fine using it.
    We've had quite a few with the tops blown out in the last wind storm that I still need to process. The white can be very gnarly. I've still got several chunks that I gave up trying to split sitting out by the pit waiting their turn.
  9. Horkn
    I burn pine. I've burnt white pine in my quadrafire insert.
    If you give it a year, it will be very very good burning wood.
    Yes, you'll burn a lot more of it, but use it to burn down coals or just for a quick take the chill off fire.
    White pine is 14 mbtu's a cord and oak is 24 mbtu's a cord. So it's not half, but you'll definitely use more pine than oak.
  10. brenndatomu
    I think in effect its half because many hardwoods will keep on throwing a lil heat from the coals while pine is done as soon as the flame goes out pretty much...unless you have a soapstone stove, or some huge mass stove...
  11. Horkn
    True. The hardwood will throw out heat a lot longer.
    I'd take it though, especially if it's close
  12. brenndatomu
    Hawdahs gotta hoard :yes:
  13. Backwoods Savage
    As long as you have the room, I say get it. You can even burn it in the cold of winter but best to burn it during the daytime hours and burn hardwoods at night so the fire will hold longer.
  14. Backwoods Savage
    I think the heat from the coals is taken into account with the btu's. For sure it has to be as you can burn just coals for quite some time. Of course you won't get those coals with pine and that is why you have to add fuel more often.
  15. Canadian border VT
    Get it!! Of course, just stack it separately.. If its 45 and damp why burn oak so the wife opens the Windows?? You stack it separately so its easy to get BTU you want when you want them..
  16. metalcuttr
    metalcuttr
    western WA
    BeechNut The old saying that the best firewood is what is free and close 95% true. I can get lots of Cedar Deodora around here which has a similar BTU to white pine. Also burn a lot of Fir. We use the soft woods to get a good bed of coals before adding the "hard to get going" woods like oak or medrona. On the other hand, I would not trouble to cut, split and stack cottonwood or alder if it was laying across my driveway. Well maybe I would only cut the cottonwood or alder out of the way if I needed to get to the store or if I knew company was coming. Then again maybe not. It would depend on who the company was.
  17. Gpsfool
    Gpsfool
    U.S.A.
    Burn pine?!?! You’ll go blind, sterile, and burn the whole neighborhood down. On top of that it causes magnetic north to wobble on its axis. No sir - do not even think of burning it.
    As a community service send it all my way for proper disposal.
  18. moresnow
    moresnow
    Pine is fine! My place is surrounded by E.White pine. I've been processing and burning it whenever mother nature topples one. I really like it. Easy to cut. I split the easy portions and campfire the tough stuff. Seasons quickly. Leaves almost zero ash deposit when done (actually kinda hard to believe how little!). I'll bet you enjoy it after giving it a try.
  19. bear 1998
    bear 1998
    S.C.Pa
    Is there a better time of year to cut pine.....I cut some n gots the sh!ts of all the pine tar (sap). Gets all over your saw,gloves,etc. I realize if that's basically all you have to burn...that's one thing.
    Just askin?
  20. Backwoods Savage
    Yeah, the sap can be a problem...or not. We still like to go to the refrerator and get a dab of Miracle Whip. Like Brylcream; a little dad will do ya.
