Flooded small engine
Discussion in 'Chainsaws and Power Equipment' started by grandgourmand, Jul 24, 2022.
  1. grandgourmand
    grandgourmand
    Ontario
    So I was trying to start my splitter and I think I pulled it too many times with choke pulled. Now it won’t start.
    i watched a couple YouTube videos saying remove air filter and clean out spark plug. Is that the way to go?
    Screwloose likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Trying to start it with the throttle wide open and choke off usually works if there is nothing else wrong.
  3. corncob
    corncob
    Somewhere in Lower Michigan
    Or a shot of starting fluid in the carb with the choke off.
    Screwloose, grandgourmand and huskihl like this.
  4. brenndatomu
    This
  5. Warner
    Warner
    :eek: Starting fluid! :cool:
  6. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Screwloose and Eggshooterist like this.
  7. grandgourmand
    grandgourmand
    Ontario
    Seems like we have consensus. If it makes a difference I can smell the gas when I pull it.
  8. brenndatomu
    I does...very likely will fire up when set to choke off/throttle wide open...if not pull the plug out and clean/dry it off
  9. grandgourmand
    grandgourmand
    Ontario
    Update....pulled the plug out (PITA without the right socket length). Brushed it off...didn't look too dirty. Took a look at the air filter...wasn't wet.
    Put it all back together and fired it up. Works like a charm!!
    isaaccarlson, Fifelaker, Ohio and 2 others like this.
