Flex Liner Cleaning
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Skier76, Oct 10, 2016.
  1. Skier76
    Skier76
    CT and SoVT
    How do you guys clean your flex liner? I was going to grab a pellet brush from Amazon, but a few of the reviews stated that the flexible handle wasn't rigid enough to get the brush through the liner. Wondering if I would have the same issue.
    I have some ridged brush rods up north I use on my wood stove chimney. Wondering if those would be a better option.
    Also, 4" diameter on the liner?
    ttdberg likes this.
  2. PelletHound
    PelletHound
    SE Ma.
    I just got cleaning my flex liner with the lint eater and the rods are a little bendy,but they made it all the way to the bottom.If you have the ridged rods that would probably work better.Now I just have to fill the hopper and fire that sucker up.:salute:
    slvrblkk and ttdberg like this.
  3. imacman
    imacman
    Denver, NC
    Agree w/ PH....I'd use a Lint Eater or Soot Eater......having the brush spin while you feed it into the liner should do a much better job, IMO.
  4. richkorn
    richkorn
    SE CT
    I use lint eater with 4" brush 25' up works great.
    Also use on drier vent....
  5. ttdberg
    ttdberg Pellet Pig
    CT
    Same here, the gardus lint eater. The wands that come with it did not provide sufficient length, so I picked up the extension kit as well. Works perfectly.
  6. imacman
    imacman
    Denver, NC
    OK, I have to add this....IF you get the Lint Eater (don't know about the soot eater), make sure you do NOT spin the drill in reverse while the brush is up in the liner.....it can unscrew easily and end-up stuck in there. Just keep turning the rod clock-wise even while pulling the brush out. :D
  7. ttdberg
    ttdberg Pellet Pig
    CT
    X2!
    slvrblkk and jtakeman like this.
  8. Skier76
    Skier76
    CT and SoVT
  9. imacman
    imacman
    Denver, NC
    Skier76 and SKEETER McCLUSKEY like this.
  10. wildwest
    Wyoming high plains
    Hey guys I have rigid pipe for the pellet stove, but a flex liner for the wood stove. Would my soot eater work for wood too? Thanks and sorry for the detour on your thread.
    Skier76 and jtakeman like this.
  11. Skier76
    Skier76
    CT and SoVT
    imacman likes this.
