Fisher - Hinge Pins
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by shack, Oct 24, 2018.
  1. shack
    shack
    Upstate NY
    What's the best stove ever? A Fisher of course. I am biased and will not entertain any other opinion on this.:p
    But, seriously, the Baby Bear is in great shape. Has a nice flat door, and the hinge pins are nice and straight....but....the pins need to be lubricated...what to use?
    Last year I cheated and used cooking spray as a quick fix, did fine to get me through. There has to be something better?
    Graphite, White Lithium, Never Seize...I can think of something wrong with all of those...don't want to have anything dripping or stinking up the place.
    What do you use? ( WeldrDave )
    Chaz, WeldrDave, TMACK and 1 other person like this.
  2. TMACK
    TMACK
    Minnesota
    Agreed best stove ever!
    On my mama bear and my copy cat timberline I use silver anti seize. Works well but use small amounts. Repeat couple times a season.
    Chaz, WeldrDave and shack like this.
  3. WeldrDave
    Pam! That's all I ever use. I take one out at a time spray it and put it back. They really were never lubed up from the factory but I have heard some putting high temp EP bearing grease on them. o_O I wouldn't, stick with Pam when they start squeaking. :yes:
    shack, brenndatomu and Chaz like this.
  4. TurboDiesel
    I thought the hinges were supposed to squeak !:emb:
    shack, WeldrDave and brenndatomu like this.
  5. JB Sawman
    JB Sawman
    pennsylvania
    I have used dry graphite powder on my home heater seems to work well
    shack and WeldrDave like this.
  6. shack
    shack
    Upstate NY
    Umm...Dave...I am not telling you how to live your life...but...I don't think any of us really want to know about what goes on with you and this woman named "Pam"... does she make you "Pam-Cakes"? :rofl: :lol:
    WeldrDave likes this.
  7. Coaly
    Coaly
    NE PA
    I never smelled anything from using high temp grease or silver anti-seize.
    I prefer anti-seize since it is higher heat rated than any grease I've found. If you grease it at the end of the heating season, it is good to protect all summer when higher levels of moisture condense on the cold stove parts. Then once mid winter.
    Open the draft caps and use a brush from the can on the air damper threads as well. Keeping both threads and hinge pins lubed prevents wear on all the moving parts.
    WeldrDave, TMACK and shack like this.
  8. Jnb
    Jnb
    New Brunswick
    I have copper anti-seize that is meant for high temperature applications that I use on manifold bolts on engines, that should stand up to the wood stove.
    shack likes this.
  9. Coaly
    Coaly
    NE PA
    Actually "PAM" is a GUY. ;)
    It stands for Product of Arthur Meyerhoff. It is canola oil.
