First harman snag
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Charles Ingalls, Apr 3, 2016.
  1. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    What kind of appliance adapters are you harman guys using. They only duravent adapter I can find for harman is the pro series and I have the older duravent pipe. If I cant find something that works for my duravent setup I have to drop 700$ on new pipe while mine my duravent is 1yr old and I spent 500$ on it
    ivanhoe and IHATEPROPANE like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    It still might work even though one is Pro and yours isn't. You might just have to RTV it up or silicone tape it. When I got my Quad the guy gave me all the piping. Although I couldn't use it because it was all the wrong configuration for me but most old pipe (regular DV) and Pro seem to fit together except one that was really corroded. Just got to seal it up.
    Maybe someone else can chime in on it.
  3. will711
    will711
    Pocono Mts.
    IHATEPROPANE, ivanhoe and slvrblkk like this.
  4. imacman
    imacman
    Denver, NC
    IHATEPROPANE, gbreda, ivanhoe and 2 others like this.
  5. will711
    will711
    Pocono Mts.
    Good call Pete I forgot about him :yes:
    IHATEPROPANE and ivanhoe like this.
  6. imacman
    imacman
    Denver, NC
    A really good guy, great to do business with, he's a Vet, (AND he owes me a LOT of smoothies!!!). :D
    will711, IHATEPROPANE and ivanhoe like this.
  7. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    I was under the impression that duravent pro and regular dont connect. But if your telling me other wise that would great
  8. slvrblkk
    slvrblkk
    Northampton, PA
    I don't think you're supposed to mix them but you're just going from adapter to the rest of the vent. Can't hurt to try it.
  9. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Im confused. Are you confirming they fit Into one another and twist lock?
  10. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    I think your not supposed to mix them because one is multifuel and one isnt which means nothing to me cause im only burning wood pellets. Just need to know if that harman duravent adapter will fit into that regular duravent. Wish somebody stocked one local so I could test fit it
  11. slvrblkk
    slvrblkk
    Northampton, PA
    The Pro has a silicone gasket internal in the piping that seals the pipe so you "shouldn't" have leaks.
    What I'm saying is the pieces of Pro that I had fit together with old style DV that I have BUT I did not use it because the few pieces the guy gave me didn't work out with the configuration of vent that I needed here. Whether it's going to work for you mixing the piping........I don't know.
  12. Pete Zahria
    Pete Zahria
    New Hampster
    I used all the stuff from Lowe's,
    adapter and pipe they stock. Not the pro stuff.
    Installed two P68's.. had no issues.
    if that is any help.
    Dan
  13. bogieb
    The mix works. Make sure you go ahead and tape up the seam with silicone tape.
  14. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Thanks guys. You have been helpful in my first couple confusing harman days. Thank you for the patience
    will711, IHATEPROPANE, gbreda and 2 others like this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
  16. jtakeman
    X2 and a few :cheers: too!
    IHATEPROPANE, artc, Russell and 2 others like this.
  17. ttdberg
    ttdberg Pellet Pig
    CT
    If it helps, you do not need the special Harman appliance adapter. I went through this when the P43 was installed. They make a special part number that's supposed to be specific to the Harman flue outlet and I thought I needed that part. Come to find out, it is not necessary, I went with the standard duravent appliance adapter and it fits perfectly. You should not need to mix and match at all.
    ivanhoe, IHATEPROPANE, gbreda and 3 others like this.
  18. Charles Ingalls
    Charles Ingalls
    Sleepy Hollow, MN
    Thanks tt. Comforting to hear that
  19. Lousyweather
    Lousyweather
    *big sigh*......duravent = leaks and callbacks, having to seal joints, tees, elbows. ICC. They even make a bolt on Harman adapter, which connects directly to the stove body....no leaks, no having to worry about seal failure either.
    imacman, ivanhoe and slvrblkk like this.
  20. gbreda
    gbreda
    NH
    I have had to seal my ICC elbow with tape. Replaced it and the second was the same so I just taped it.
