Firewood moisture
Discussion in 'The Wood Pile' started by Reloader, Mar 30, 2022.
  1. Reloader
    Reloader
    NW Oregon
    I filled up the wood shed in January with wood that had been stacked out in the rain. Checked moisture on some splits and it’s right around 15.5% after about three months under cover during a rainy Winter.
    Some wood that’s been under cover for two years is showing about 12.5% on the outside as I didn’t split any to check.
  2. T.Jeff Veal
    Sounds like it is about ready for this fall.
  3. The Wood Wolverine
    Anything under 20 is good enough for me. Proof is there during my flue clean outs.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  5. brenndatomu
    It might be 12.5 inside too...but testing the outside is generally meaningless.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    Measuring outside is not meaningful. You need to split a split and measure on the fresh face of the split. Outside will dry a lot quicker than the inside.
