Firewood Marking
Discussion in 'The Wood Pile' started by rusty ranger 44, May 24, 2021.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    Members - How do you mark your firewood to be cut to length. I started by using a hatchet and tape measure, marking at 16" intervals, but have changed to using sidewalk chalk and tape measure to marking 16" pieces. With so many options out there , So what do you say is best method for you.
  2. Andimus Prime
    Andimus Prime
    NW NC
  3. MikeInMa
    Yardstick and chalk
  4. Biddleman
    Biddleman
    River Hills of Pennsylvania
  5. JDU
    JDU
    Perry County, PA
    Tape measure and lumber crayon.
  6. Chud
    Chud
    NC
    Mingo with 18” wheel
  7. EODMSgt
    EODMSgt
    White Mountain Region, NH
  8. Warner
    Warner
    image.jpg My marking stick.
  9. scarps68
    scarps68
    CT
    Mark 18" with a paint pen on my bar. Dip the tip each time, then go back and cut them all
  10. moresnow
    moresnow
  11. Slocum
    Slocum
    North Central Indiana
    JDU, Horkn, Chazsbetterhalf and 4 others like this.
  12. amateur cutter
    24" threaded rod thru the bar on a small saw. It has 16" & 18" marks on it as well. The Milwaukee battery saw gets this duty a lot.
  13. VelvetFoot
    VelvetFoot
    Sand Lake, NY
    I use a 16" piece of yellow fiberglass driveway marker rod. I don't mark the log, just eyeball where the rod end was. It's easy enough to keep in hand when sawing.
  14. Erik B
    Erik B
    Western Wisconsin
    Using a tape measure and sidewalk chalk works for me. I have tried to use a Mingo marker but with logs laying in the woods and I don't have equipment to get them out, it is hard to keep up a steady pace walking when you are having to navigate all kinds of stuff on the forest floor which leaves long streaks of paint instead of dots of paint..
  15. Road-side Oak
    Road-side Oak
    Southern NJ
    +1 on the Sidewalk chalk and tape measure
    JDU, Horkn, Chazsbetterhalf and 5 others like this.
  16. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I cut to what I can lift. The woodwhore will eat 48" on the bottom and 32" up higher. My stacks would give someone with ocd a heart attack. I spend enough time cutting and stacking as is, I don't want to add another step.
  17. stuckinthemuck
    stuckinthemuck
    I carry an 18” long 1/2” diameter stick in my hand as I cut. Prior to each cut, I lay it on the log and eyeball where my next cut should go. It’s generally good for plus or minus 1/2” and is small enough I can hold it and the top handle of my saw in my left hand while cutting.
  18. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I use 18” bars and I marked lines on my longer bars with a sharpie 18” from the end of the bar and from power head side. I hold the saw up parallel the the log I’m cutting and eye ball a spot in the log. Works good for me and no extra equipment.
    when I get a 400 with 20” bar I might have to start bucking at 20”, I’ll have the measure my firebox first and make sure 20” will fit!
  19. buZZsaw BRAD
    6' folding carpenters ruler and piece of sidewalk chalk. Ruler in back right pocket, chalk in front right pocket. On very rare occasions ill use a tape measure but it usually unhooks from the end.
  20. Locust Post
    I don't measure. My stove will take 22" and I am pretty good at getting close to 16 - 18" My stacks are not as uniform as some I see posted but I don't sweat it.
