Fire start up
Discussion in 'Modern EPA Stoves and Fireplaces' started by dylantdyck, Nov 25, 2018.
  1. dylantdyck
    dylantdyck
    CA
    Hey guys I'm new to heating with wood so far it's been going good but i started using the log cabin style and it starts up really easy but it gets hot really fast and i pretty much have to keep the damper shut to stop it from overfiring and i didn't have to before with all the logs north south i'm assuming it's just because of more airflow?
    Sent from my SM-G950W using Tapatalk
    HDRock, Backwoods Savage and Marvin like this.
  2. Marvin
    Marvin
    Huntingdon, Pa
    I think that would be a safe assumption. Keep experimenting. You'll find what works best for you.
  3. Backwoods Savage
  4. Woody Stover
    Woody Stover
    Southern IN
    It sounds like you have good draft. Another way to start a cold stove is the "top-down" method. Load big splits in the bottom/back, a couple of small splits top/front, and a couple sticks of kindling and a starter on top of those. This will heat up the top re-burn section of the stove quickly, and create less smoke outside since the smoke from the wood that's catching fire is rising into the flame and being burned. It will also burn up the smallest amount of wood while you get the stove up to temp.
    Maina likes this.
  5. HDRock
    Yes , Absolutely , Stacking the wood in the stove log cabin style There is much more air flow around the wood So It will burn hot and fast and won't last as long
    Maina and BuckthornBonnie like this.
  6. dylantdyck
    dylantdyck
    CA
    That's not it I'm hoping is either the door seal or that i just need to tighten the door I've only had the stove for a month
