Finally got a splitter..
Discussion in 'Chainsaws and Power Equipment' started by smokebuzz, Nov 3, 2022.
  1. smokebuzz
    smokebuzz
    IOWA
    Obviously I'm get old.. got a splitter tonight. Had 2 brands in mind, but missed out on a yard max a couple weeks ago. Tsc got 2 of theses in on Monday, both left at the same time tonight..[​IMG]
    Sent from my SM-G981V using Tapatalk
    Skier76, T.Jeff Veal, NYH1 and 29 others like this.
  2. Ohio
    Not Ohio
    Nice splitter! I bought a dirty hands tools 25 to splitter and they went bankrupt a year later. Wish I would have bought a county line splitter just across the street at TSC. Get a side table its a back saver. Best of luck with your new investment!
  3. metalcuttr
    metalcuttr
    western WA
    Good for you! You will wonder why you didn't get one sooner and Welcome to the forum my friend!
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Sweet spliter, I think you will like it. I had the older, non fast, 25-ton until upgrading to the fast 30-ton, the only one TSC had. First log.jpg
  5. Mag Craft
    Mag Craft
    South East Wyoming
    Congrats on your new splitter. Getting older does have its perks.
  6. Chvymn99
    Congrats on the new splitter!
  7. buzz-saw
    buzz-saw
    Ct.
    Nice. You will ask yourself why not sooner.
    Keep the oil clean and it should last you many years.
  8. Backwoods Savage
    They do tend to make the work faster and easier. Best to start splitting right too; vertically. No table required.
  9. Yawner
    Yawner
    Louisiana
    I was going to make that very comment... I split vertically, sitting and split mostly oak.
    I hope you have good luck, I have this very machine. Mine has Kohler 265 6.5hp motor. I just replaced the carburetor (twice in a week), and hope this particular one works long-term. Only have had one day-long splitting session with this 2nd new Chinese clone carb. Also replaced in the past a hydraulic hose and also the main valve failed. It has certainly not been trouble-free but I don't know what 'normal' troubles users have with other makes. Mine seems to have had an inordinate amount of issues. When it works, I guess it's pretty good and decently fast. I couldn't stand to use some splitters that are much slower!
    I note that your new model has a spring-loaded front stand, mine does not have a spring. Maybe they have made other improvements.
  10. WinonaRail
    WinonaRail
    Indiana, US
    Consider picking up the slide-on 4 way wedge. It's not very heavy but does a good job on the right size wood.
  11. Yawner
    Yawner
    Louisiana
    You found it to work good? I have not bought one because others have reported that it is way too lightweight and won't hold up. And I split mostly oak anyway, might be a test! But I'd sure like it if it would work! Do you think it would work on red maple or cherry or similar less dense wood?
  12. In the Pines
    In the Pines
    I really like my countyline, I second the motion on picking up the side table it is well worth having.
    I also bought a magnetic dipstick for it as well as a drainzit line. It sucks draining the oil on that splitter.
    The engineers definitely didn't think that thru I guess, it drains all over the engine mount and than goes where it wants.
    Unless you roll the one tire up on a block so it angles.
    I use the stock wedge, it works well enough for me. I like to choose how "thick of a slice" I want when I split it.
    After using it for a few hours you will know if you want one though.
    PS: be careful with that plastic can they give you for the manuals, I broke mine the minute it came off the truck, I assembled mine though as well. Either way, the mounting ears a bit fragile.
  13. buzz-saw
    buzz-saw
    Ct.
    A couple other things that might help , you can take it or leave it.
    Install an hour meter , inexpensive and a great way to keep track of maintinance and splitting time.
    Wrap the oil filter with flexible magnetic sign like they use for vehicles. This helps pull small particles out of the oil that are floating around in there and they stick to the metal can of the filter.
    Just my 2 cents.
  14. WinonaRail
    WinonaRail
    Indiana, US
    I bought one for half price for my 27 ton Black Diamond splitter. Drops right onto the factory wedge. I use it mostly on 8"-10" rounds, probably less than 10% of my total splitting time. The horizontal wings are too short to work on anything much larger. If I have a lot of limb wood, I try to stage them all at once to use the 4 way. Also, I've never used on elm or anything stringy. I doubt it would be very helpful.
  15. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Is that a black diamond? I’ve looked at those, trying to convince my boss to get a decent splitter at work. The one we have was built by his dad, and with just a couple more modifications it would be COMPLETELY UNHANDY AND TERRIBLY USER UN FRIENDLY.
  16. In the Pines
    In the Pines
    that kohler engine doesn't have an oil filter- all you can do is use a magnetic dipstick.
    I agree with the hour meter it was first thing I installed on mine. than the table
  17. buzz-saw
    buzz-saw
    Ct.
    Sorry , I should have been a little clearer.
    I meant the Hydro Filter.
  18. In the Pines
    In the Pines
    haha no you're right I haven't had enough coffee and wasn't even thinking of the hydro filter. It's a good idea. I went and bought a wix filter for mine.
    Threw away the stock one after 5 hours of use.
  19. The Wood Wolverine
  20. smokebuzz
    smokebuzz
    IOWA
    Where did you get the magnetic dipstick?
