Fence posts. Prepping and hole auger
Discussion in 'Chainsaws and Power Equipment' started by Cold Trigger Finger, Apr 14, 2021.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    So. I gotta build a fence.
    I have Fire killed white spruce fence posts that range from 3" to 6" diameter . My hope is to find a dirt auger bit that I can use with my Makita Hole Hog.
    Anyone know where I can find auger bits .
  2. Chud
    Chud
    NC
    I think I’ve seen bits at Home Depot. They sell Echo products. An ope dealer with a decent amount of inventory. I know Stihl makes hole diggers. Tractor Supply should have some different sizes. I’d think bit attachment is universal whether it’s pto driven or portable gas.
  3. eatonpcat
    TSC sells augers and parts for augers...Not sure you have TSC in Alaska though!
  4. Flamestead
    Flamestead
    Windsor County, VT
    I prefer a driven 3” post, due to all the tamping required to backfill. Iron bar to open the hole, and a sledge to drive it in. In my younger days. Really depends on the soil - a gravel would refill the hole more firmly that the silt-loam I grew up on.
  5. Homemade
    Homemade
    Wisconsin
    They make an adapter to run a hand ice auger with a drill. Never tried it in dirt though.
  6. eatonpcat
    I would like to see the drill that you could dig a 12" diameter hole 4'-0" into the ground...
  7. Eric VW
    Sounds like a wrist/arm relocator.
    :startled:
    :pain:
    More emphasis on a bandaged upper body part. :confused:
  8. OhioStihl
    OhioStihl
    Southern Ohio
    I ran a hand held auger when I was younger. It was gas powered and it looked like I was fighting a black belt in jujitsu. I lost.
  9. jo191145
    jo191145
    Ct
    Often wondered if you could mount one of those screw splitters to a hand auger and split wood,,,,,,,alive.
  10. Homemade
    Homemade
    Wisconsin
    Ice augers are max 10” and they make them as small as 4” that I’ve seen. It’s the op looking for a way to drill holes with his Makita hole hog. I know my Milwaukee super hole hawg has a clutch to prevent the wrist twist when drilling large diameter holes. I think it’s rated for a 4.5” Forstner bit in wood.
  11. SloMoJoe
    SloMoJoe
    SW Michigan
    I have a 24" x 2 1/2" auger for my drill for drilling holes for tulip bulbs. It works OK, so long as you don't hit a rock or a root. Drains the battery amazingly fast, though. It might work for a pilot hole, and then you can follow it with something bigger. I think I've seen them up to 3" or so.
    Flower Bulb Hex Drill Planter Large
  12. Cold Trigger Finger
    Cold Trigger Finger
    Driving fence posts was part of growing up. White cedar , 6' long posts with 4 been cuts. Steel bar to punch in the hole. And when things were perfect, someone to drive the tractor and a hay wagon to stand on. No idea how many hundreds I've driven. But I do know that is how I learned how to swing a sledge equally well right or left handed. Use 1 arm until it was too tired. Switch hands and use the other one till it wouldn't work. Repeat.
    I even came up with a 14 lb fence post maul head recently. BUT ! !
    I ain't the man I used to be !
    Hence the auger.
  13. Cold Trigger Finger
    Cold Trigger Finger
    I was hoping to do up to a 6" around 2 ' deep.
    I know my drill will run a 4 5/8" self feed bit thru dry oak. As long as I have something solid for the long aux. handle to push. I can't hold it.
    This will be a 12 strand electric fence with 2 different zappers hooked to it. A mild one on the inside for 3 strands . And the hottest one I can get for the outside 9 strands . at least 17,000 volts .
    amateur cutter and eatonpcat like this.
  14. Cold Trigger Finger
    Cold Trigger Finger
    Yes . Mine is the Makita version. But it doesn't have a clutch.
    amateur cutter likes this.
  15. eatonpcat
    That ought to stop the escapees!:drunk:
  16. Homemade
    Homemade
    Wisconsin
    It’s the amps that kill you, not the volts.
  17. Cold Trigger Finger
    Cold Trigger Finger
    It will be on the outside of the posts. To stop moose and bears and other predators.
    The inner 3 strands will be just enough to give our animals a sufficient zap to stay away from the real hot wires.
  18. Cold Trigger Finger
    Cold Trigger Finger
    Yup. But the high volts sends a nice big blue arc. I've watched a 7' grizzly get knocked over by 17k volts. And that was the Last time it tried to get thru the fence @ the Glennallen Landfill. 5 generations of bears had grown up eating at that dump/landfill.
    1 season having the electric fence around it and they all went away. It ran off somewhere around 30 different bears. They would show up in the spring . once the salmon started coming in they would all pretty much be on the river and criks. Then top off their tanks in the fall before going into hibernation.
    Eckie, amateur cutter and eatonpcat like this.
  19. Cold Trigger Finger
    Cold Trigger Finger
    So, I found out the local equipment outfit rents 2 man post hole augers. 50 bucks a day. With 1 bit. I wonder if I can drill 110 holes in a day. The smallest bit is a 6".
    But they may be able to get a 1 man unit.
    eatonpcat and amateur cutter like this.
  20. amateur cutter
    If it were me I'd try & get a second person & use the two man. I put 30 holes in with a one man & felt like I'd been beat by a pro fighter. Hit a stone & it yanks it right out of your hands or tears your shoulder. Which if I remember correctly you just had fixed. Very unpleasant machine to run if you have stones or gravel soil.
