Felling Curved Trees
Discussion in 'The Wood Pile' started by Kimberly, May 4, 2017.
  1. Kimberly
    Kimberly
    The Kangaroo State
    There is a tulip poplar I would like to drop. If you look at it from one angle it is straight as can be. Walk around to a different angle and it is curved. It also seems to have most of the branches on one side. Is there any tutorials on dealing with curved trees I can read or watch? I meant to take photos but forgot. I am working down in the little valley removing trees that shade the garden before I put the fence back up to keep the varmints out. I found a raccoon track in the mud at the lower end of the garden.
  2. yooperdave
    Cut the tree, shoot the racoon.
    Barcroftb, blacksmith, axeman and 8 others like this.
  3. brenndatomu
    Could shoot the tree and cut the coon...that might be fun. :whistle: :D
    Is the tree curved and therefore weighted in the direction you want it to go?
    Barcroftb, Rumpy, Horkn and 5 others like this.
  4. yooperdave
    I am thinking the tree will be heavier on one side, no? According to the description anyway.
    Barcroftb, blacksmith, Horkn and 2 others like this.
  5. Eric VW
    Is this the same wonky tree you posted about some time ago?
    Barcroftb, blacksmith and Horkn like this.
  6. brenndatomu
    This is a Wonka tree!?
    This is easy then...just eat all the goodies off the heavy side! :whistle: :D :picard:
    Barcroftb, blacksmith, axeman and 9 others like this.
  7. yooperdave
    No wonder there was a racoon!
    Barcroftb, blacksmith, Rumpy and 6 others like this.
  8. brenndatomu
    Yah!
    Screw the garden...plant some more of those trees!
    Back to our regularly scheduled programming...:emb:
  9. Kimberly
    Kimberly
    The Kangaroo State
    No. There is no way I would try to attempt that tree; although it does shade the garden.
    blacksmith, Horkn and XXL like this.
  10. Mag Craft
    Mag Craft
    South East Wyoming
    Just try and determine which way the lean is and the weight is and fall the tree in that direction. You could also pull it over with your tractor or any other motorized vehicle.
    blacksmith, axeman, Horkn and 4 others like this.
  11. FatBoy85
    FatBoy85
    Washington State
    Shooting the tree, lotsa kindling.
    Horkn, Shawn Curry and brenndatomu like this.
  12. bocefus78
    bocefus78
    Indiana
    Read up on a "barber chair". Trees with lots of weight on one side or a heavy lean can get dangerous real quick.
  13. Scotty Overkill
    Felling curved and/or leaning trees can be a tricky endeavor, depending on the size of the tree.....
  14. Mag Craft
    Mag Craft
    South East Wyoming
    Any tree is a dangerous proposition to fall. You should be carful with them all not just the curved ones.
    blacksmith, Rumpy, Horkn and 2 others like this.
  15. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    I've noticed this around here with some of the white poplar aka aspen. I find it's easiest to find it's true lean when you stay back a fair distance and eyeball it. It's almost like an optical illusion up close, especially if the surrounding terrain is uneven.
    I also think some trees try to compensate for their lean by growing out the other way. Kind of like a tree has a gentle lean to the right, but then it leans back slightly left, and more crown over on the left side. Even though it looks out of balance, the center of gravity is not.
    Barcroftb, blacksmith, Rumpy and 2 others like this.
  16. Scotty Overkill
    Very true. I'll also add that this post, without provding pictures and an overview of the area involved, really doesn't allow a helpful comment from me.
  17. yooperdave
    I would strongly urge against offering any advice for fear of liability issues...."I was told to do it this was" type of scenario.
  18. Kimberly
    Kimberly
    The Kangaroo State
    This whole forum is full of advice about felling and bucking and using saws; I don't think there is any issue that the forum would need to shut down due to liability issues. The same is true of video sites as well. Sthil has produced a whole range of videos as well as universities and colleges and state agencies.
    Hopefully this will be the end of this, Yopper gave his opinion and I have given mind; everyone should be happy.
    blacksmith and Mag Craft like this.
  19. Kimberly
    Kimberly
    The Kangaroo State
    The idea in posting was to learn how one gauges balance, centre of gravity, etc with trees in order to know where they will tend to want to go naturally without wedging; especially on trees where there is no room to wedge. I have watched some videos where the person walks around looking at the canopy with the arms upright to help frame the canopy to see how it is balanced at the top. This tree also has a curve in the trunk so that must affect the balance of the tree.
    blacksmith likes this.
  20. yooperdave
    I was not referring to you krimberly
    Babaganoosh likes this.
