Fairly new saw seized
Discussion in 'Chainsaws and Power Equipment' started by dennish, Aug 18, 2023.
  1. dennish
    dennish
    Nor Cal
    After several pulls in attempting to start, the saw seized. Cannot pull the cord. Thoughts on how to free up the saw.
    Screwloose, buZZsaw BRAD and MikeInMa like this.
  2. MikeInMa
    Is the chain loose to move by hand?
    Try to start without the bar and chain on.
    What make and model? How old? Last used?
  3. Chud
    Chud
    NC
    Sounds like a Husqvarna. Jk simmer down. Sometimes those hanging curves are irresistible. Jokes on me if it’s Stihl. Have a nice weekend. Hope your new saw is not seized.
  4. The Wood Wolverine
    I agree with Mike, remove bar and chain and see if you can pull the cord. If not, are you able to pull the recoil/starter cover to see if the pawls are messed up? After that.. sometimes a screw can get lodged in/around/behind that flywheel which will stop it from turning. Look for that. IF all that was fine, next step for me would be pulling the muffler off the saw to look at the condition of the piston.
  5. buzz-saw
    buzz-saw
    Ct.
    I would guess myself that it is not seized and there is something else wrong ; recoil?
    Can't imagine that it would seize from just pulling the rope. That cylinder would have had to been extremely dry to lock up.
  6. lukem
    Take bar and chain off and try, as others said. If that doesn't free it up take the starter assembly off and see if you can turn it over using a wrench on the flywheel nut.
  7. Redneck
    Redneck
    Burton mi
    Does it have a decomp button. If not pull the spark plug then try to turn it over.
    May be vapor locked if it flooded out.
    M2theB and Screwloose like this.
  8. buZZsaw BRAD
    Throw it away and buy a Stihl! :dex: :saw:
    Just kidding. What brand is the saw?
    Screwloose likes this.
  9. The Wood Wolverine
    Bunch of Koolade drinkers in here. :loco: :crazy:
    Pretty sure he bought an Echo not long ago so hopefully there’s a warranty to lean on.
  10. Eggshooterist
    Eggshooterist
    Erff
    I'm pretty sure Pusqvarna has its share of Koolade drinkers...
    :thumbs:
    JimBear and Screwloose like this.
  11. Eggshooterist
    Eggshooterist
    Erff
  12. Eric Wanderweg
    Yeah there's no way you seized the piston in the cylinder by pulling the cord. Even if you were pulling like a madman with straight gas in it that wouldn't happen. Seizing takes heat/friction. Unless the ring broke... But others gave you solid advice previously. Start with the easy stuff and go from there.
  13. dennish
    dennish
    Nor Cal
    Thanks all, fixed it. The main cause/fix was the spark plug. Removed, and it turned over. Started up.
  14. buzz-saw
    buzz-saw
    Ct.
    hydro locked? Maybe??
    up and running. That’s a good thing. Glad you got it fixed.
    Screwloose, metalcuttr, Mrxlh and 3 others like this.
  15. MikeInMa
  16. The Wood Wolverine
    I was curious on that too. Spark plug typically doesn’t make a saw seize.
