I have 50F #2100 that has been a subject of a few comments by the late DexterDay on a few of the pellet threads. Kenis was my BIL and even before his passing I had enough of the pellet life and switched to a heat pump and the Fahrenheit has sat idle in the basement for years. In my case, life changed and spare time is fewer, and it is simpler to adjust the stat than to deal with the pellets. I used as my primary heat from 2013 and did a good job keeping my 1400 sq ft ranch comfortable with any box store pellet I fed it, even did Cherry pits a couple times but typically Somersets was the main diet. My last year running the furnace (2019?) I was chasing some issues with auger timeouts during startup, and after replacing and adjusting this and that, and ultimately replacing the thermostat, the engineer that Kenis was friends with at Farenheit (Matt?) said we were down to the control panel to fix the issue. That spring I put in a new furnace/heat pump and this thing has sat in the basement since and I use it as a bench. Looking to sell the furnace, hopper extension, any extra gasket materials, burn plate, manual, some more manuals that Kenis had made me copies of from Farenheit, parts lists etc. and approx. 1/3 pallet of hardwood pellets (brand escapes me as they are at my warehouse under the plastic) and likely a couple pieces of triple wall duravent pipe somewhere in the garage (I used my stainless chimney liner for the new furnace so that does not go). The furnace had all updates (as of that time) and the majority of the Mods, that Kenis did on his that he thought were worth it on my unit. I have no idea of going rates on the used market and know the control panel at the time was about $300. If there is interest, let me know and make an offer. I am in the NE Ohio area Youngstown/ New Castle, Pa area. If interest in pics, I will need to clean up the basement around it and remember how to get the burn pot out and such as its been awhile... Thanks, Chris
