extending a hearth
Discussion in 'Modern EPA Stoves and Fireplaces' started by rocky99, May 20, 2024.
  1. rocky99
    rocky99
    adirondacks, ny
    I want to purchase an jotul oslo f500 but my existing hearth is only 48x48 inches. Is there a way you can buy various widths of fireproof material that would "attach" to the existing hearth to make up the extra width necessary for this stove? thank you.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    The easy answer..... maybe. Some specifics might help someone help you. Can't be much more vague than the original post.
    T.Jeff Veal and metalcuttr like this.
  3. brenndatomu
    Search "hearth pads"
    Stove Boards & Hearth Pads: The #1 Stove Board Dealer (efireplacestore.com)
    You will need to know what R value your stove requires...
    T.Jeff Veal and wildwest like this.
  4. rocky99
    rocky99
    adirondacks, ny
    This is what I know. The stove literature says I need an R value of 1.6. The existing hearth is made of 1" cut granite laying on top of 0.4 inch of what I called when it was built in 1985 "asbestos board". Not really sure what it's makeup is.! I still have a large chunk of it left over that I can use. This is all on top of a 5/8" plywood subfloor. I need to extend the hearth out about 6 inches. Sorry to be vague, but the only real given is a R value of 1.6.
    wildwest and T.Jeff Veal like this.
  5. brenndatomu
    Sounds like the existing hearth is inadequate for R 1.6 too...and you have an "unknown" R value on the existing insulation (unless you can find some hard data on it) and that granite is near zero, so...
    I think I'd just start over so that you know what you are dealing with for sure...Micore 300 is R 1.03 per 1/2", so two layers of that, and then whatever noncombustible surface you want to put over it (stone, tile, steel plate, etc.)
  6. Highbeam
    Highbeam
    I hate R requirements for hearths. I think it is the result of poor engineering. They all should be ember protection only. Some very good brands still have these ancient hearth insulation requirements so if you want their stove you need to screw around with the legit insulation requirements.
    There are several materials that you can use to get to R1.6. A huge stack of cement board is one.
  7. Highbeam
    Highbeam
    Here's a previous thread that starts out with the chart of materials and R value per inch.
    R values on a hearth build?
    So for example with cement board if would take 5- 1/2" sheets, 2.5" total, to get to R1.6.
    wildwest, brenndatomu and T.Jeff Veal like this.
  8. wildwest
    Wyoming high plains
    rocky99 , do you know a roofer? DensDeck is .56R per 1/2", so two would be 1.12 R and 1" high.
  9. wildwest
    Wyoming high plains
  10. blacktail
    blacktail
    PNW
    Sounds like it's not too late to choose a different stove.
    billb3, brenndatomu and wildwest like this.
  11. Highbeam
    Highbeam
    I wonder if the insulation material has to be non combustible.
    wildwest likes this.
  12. wildwest
    Wyoming high plains
    It's fire rated for flame resistance but not sure non combustible. And a non combustible covering like tile.
    brenndatomu likes this.
  13. wildwest
    Wyoming high plains
    I looked it up, tested combustibility, so atleast 1,382* F before combustion occurs.
  14. golf66
    golf66
    Pictures would be very helpful. Anyway you could post a few? Thanks!
  15. EODDiver
    EODDiver
    Nashville, TN
    My Lopi didn't require a pad with a R value, just had to be non flammable. So had a metal fabrication business make one out of 1/8" steel plate and powder coated. Was only $300 with tax.
    Ronaldo, wildwest and MikeInMa like this.
