EPA vs Non-EPA
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marvin, Oct 2, 2018.
  1. Marvin
    Marvin
    Huntingdon, Pa
    I'm just asking this out of curiosity as this will be my first year using an EPA certified stove. I've read on here about EPA stoves burning so much better when the wood you're burning is dried properly.
    My understanding of EPA stoves vs non-EPA stoves is that you cannot fully shut off air to the EPA stoves preventing the wood from smoldering. Apparently this was a problem in the old smoke dragon stoves. I understand the safety aspect of this.
    So now for my question....in theory wouldn't always having an air supply allow wetter wood to burn instead of smoldering? I can see why removing all of the air would choke a fire, wet wood or dry wood. I'm just trying to wrap my head around why older stoves are less finicky when it comes to moisture levels.
  2. Canadian border VT
    I guess my understanding is different than yours. My understanding is that the EPA stoves, burn the smoke, when the temperatures are at the correct ratios. They accomplish this through either catalytic converters or tubes that slow down the smoke flow rate.
    So therefore they burn cleaner as smoke produces Heat. Giving you more heat from less wood.
    The problem with wet wood is it cools the fire because nobody's figured out how to burn water. This lower temperature doesn't allow the smoke to burn creating more pollution.
  3. Marvin
    Marvin
    Huntingdon, Pa
    It sounds to me that you are understanding it correctly. I've never thought about it in that manner. Thanks for clarifying for me.
  4. Boomstick
    Boomstick Banned
    Saratoga county ny
    Good question!
    Probably won't get a scientific positive answer.
    You would need a thermodynamics engineer to fully explain it.:rofl: :lol:
    But, my blaze king can stall the cat(in warmer temps and poor draft aka cold pipe) and smolder much like an old stove.
    For me I simplify it as airflow. In my own head "in theory" Epa stoves need good draft, a good draft requires heat. (Lots of poor draft threads).
    I've burned not so dry wood, low heat hard starting old non Epa stoves have trouble drafting with wet wood too. They just don't need to pull air through tubes, or special inlets that requires more draft.
    Its like really dry wood and people freaking out that it will burn out of control. Only opoosite.
    Doug, bear 1998, Marvin and 1 other person like this.
  5. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Burning the wet wood just gummed up the chimney faster.
    If you are concerned about having dry wood, focus wood that doesn't need a long time to season... Ash, silver maple and pine all season very quickly. And the epa stoves don't care much about the quality of the wood in my experience.
    I truly believe that the worst part about the epa stoves is that EPA moniker. It provokes a knee jerk reaction because years of political dogma have drilled into everyone's head that anything associated with the government is bad.
    They should have just called them tube stoves.
    Mitch Newton, bear 1998, Chaz and 2 others like this.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    All good points....
    Also, the smoke dragons can burn wet wood by having virtually unlimited air supply..... This is not the case with the EPA stoves.
  7. Boomstick
    Boomstick Banned
    Saratoga county ny
    Politics has nothing to do with it.
    I believe it's the opposite. The epa being great is what is forced into everyone. Just look at the news:rofl: :lol:
    People aren't stupid.
    It's their Experiences that tell them everything the EPA-government is involved in goes to hell.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I agree with Suburban wood snob on this one....
  9. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Look, it's free country ... More or less. And we are free to disagree about things ... But I don't know of anywhere it's being ground into you that the epa is good. The opposite certainly is easy to find.
    The fact that we are in disagreement proves my point that epa moniker carries political baggage. If for instance someone posted all there great experiences with a new kind of stove that makes no smoke and uses far less wood, you would be far more inclined to be interested in them, than if I came to you and said hey your stove is too smokey and is giving your neighbor with asthma fits...and the epa has crafted this compliance box that now shall be all you can buy.
    It's just like folks game stoves for which ones have the best performance and fuel efficiency. All the ideal steal owners love to brag about the burn times and how long the wood lasts. Now if they had called themselves the epa federally mandated steel stove company they likely would have gotten nowhere..
  10. Pallet Pete
    Pallet Pete Moderator
    Ovid
    This is an interesting topic I have often debated.
    One that can really be discussed without politics involved :D;)but rather science.
    I have owned both smoke dragons and epa stoves and smoke dragons are NOT air tight stoves in my experience if they where they would go out when shut down.
    We used to burn a little wet wood thinking that it would give longer burns until we tried truly dried woodo_O what a difference that made. We went from smoking the town out to burning on avg 2 hours longer with dry wood and very little smoke.
    The best proof was that we could shut the air down and it would literally smoke for hours with the old smoke dragon. With the epa stoves you also get smoke and creosote if your wood isn’t dry. They are designed for dry wood to operate correctly.
    The old days the thought was to add wet wood to make it burn longer however it was flawed logic with our stove because all we did was dirty the flue and fill the sky with smoke. Dry wood gave more heat by far and burned hotter, cleaner and longer.
  11. WeldrDave
    Hello everyone, Pete made a very good point here and if I may, "Please" lets not beat me up on this comment. As many of you know, I worked and was in the US Coast Guard for many years. I also taught College in the metals world now that has "Nothing to do" with this subject, but I will tell you some science I have learned by working with some great Professors, Astronauts, civic scientists, USGS professors and NOAA. With "ALL" politics aside,....... Here it come's......
    There is very little you and I are going to do to hurt the atmosphere with our stoves, "EPA or Non-EPA". I don't agree with burning wet wood and killing off your neighbors, I don't agree with these folks with OWB's and burning plastic, tires, trash and anything else you can throw in them. "But" think about this. How many "BILLIONS AND BILLIONS" of acres of forest have burn't in the last 200 years and who put it out? There are fires still burning in California and other places. You never hear about the wild fires in Russia, "Google that". I have a very good friend and colleague who is a USGS professor for Volcanism and he actually laughs when the debate of wood stoves comes up. "We", us wood burners are actually contributing about .000001% of the hydrocarbons in the atmosphere "contrary" to what the news will tell you. The EPA has some good but also was given "MUCH" more power than realized. Now, the whole EPA stove was all a "feel good" law that the politicians put in place, "This is factual" not to mention we went from buying a stove that used to cost $500.00 to a stove that now cost more than $3000.00 because of catalyst and pollution control.
    Think of this also, How many campgrounds are in the united states and people burning camp fires, hundreds of thousands! How many states allow burning on your land?, many! Also, another food for thought, man has been heating their homes for "Centuries" with wood and coal. If you think it was us, "Man" with our wood stoves who is hurting the atmosphere you may want to take another hard look at it. Why do we need 18,000 satellites going around the earth?
    How did they get there? "millions of tons of solid fuel"!!! How many "BILLIONS" of gallons of diesel, bunker-C, avgas, JP-5, F-76, and other fuels burn't during 3 wars? How about the oil fields that burn't by the hands of old Sadam Hussain and burn't for over 9 months? Lastly, I boarded many, many ships out at sea but yet burning 1,800,000 gals of fuel on a ship to bring some Toyota's, Honda's, Volkswagons and other foreign cars to "America" makes sense? Well, I think you all get the picture. EPA, Non-EPA, burn what you want because it's like peeing in a Volcano trying to put it out! o_O Although I will say this, Dry wood is your best friend!!!
  12. WeldrDave
  13. Boomstick
    Boomstick Banned
    Saratoga county ny
    Hey, we're both expressing our observations and feelings there is no wrong answer!
    I more importantly respect your opinion and am interested in hearing you sharing them, as well as you hearing me.
    Sadly there are people on here that will crap down your throat for having them......
    Maybe it's age difference or location, but from the half dozen educational institutions I've been to, tv radio etc..anyone who disagrees with the epa assumably hates the earth, is stupid.. hates their neighbors etc... Disagree meaning not liking their or trying to not be a part of their ...deal.
    I've taken full letter grade reductions for not complying.
    I don't believe in force or violence...most of the time:rofl: :lol: I believe in freedom good people and the free market.
    The epa did not create cleaner stoves the private sector did.
    Sign him on here!:yes:
  14. Marvin
    Marvin
    Huntingdon, Pa
    Thanks all for the input here. I appreciate the commentary from all angles. This was just a topic out of curiosity that I wanted to better understand the logic behind it. Perhaps I should have titled this "Older stoves vs newer stoves" It was not my intention to begin a political discussion.
  15. WeldrDave
    And you didn't!!! Very good! "Sadly" .... Everything we do in one form or another is "regulated" by Uncle Sam. The points I put up are the science, "whether you believe them or not". Opinions and expressions here are "GOOD" and we try as best we can to stay out of the political fight!!! It is a sad state on that side. Marvin, everyone here has and does something a bit different,:) "that's where we all learn"! :yes: This has been posted many times before and on other forums to the point of people wanting to fist fight! This is true, any of the moderators can attest to it. It's what you believe, and if you feel you are doing "YOUR" best, then thats all you can do. :cool: There are "Chicken littles" out there that say were all doomed tomorrow but all I say is research, do your homework and enjoy what you have! :D:)
  16. WeldrDave
    He actually does read the forums! He will not put in input due to his position. Him and I have had a long friendship. :cool: I'd like to know what he forgot:doh:o_O
  17. yooperdave
    Myself, I have three epa stoves and one non-epa stove that I cannot bear to part with. I use the three but the non-epa is in storage...silently waiting.....
    Dry wood, plain and simple. Dry wood.
  18. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Do you see my point now? Calling them EPA stoves was stupid. It colors the conversation. The reality is that they do work better... Regardless of how you measure it. Less smoke? Check. Uses less fuel? Check. I would even argue that the cost argument is irrelevant. Every thing that's not electronics or high tech cost less back in the pre epa stove Era. These things date back to 1998 after all. 500 1988 dollar is 1090 2018 dollars... Which is ironically about what a large epa compliant wood stove costs today. Drolet Ht2000 ... 3.7cubes, low emissions and it's built in Canada, not some low wage hell hole in the third world. An NC30 is even cheaper... And US made. That's progress, and I like it.
    Will they cure global warming? No. Will they bring back extinct species? No. Will they fix all the ills of the world.... Obviously not. They will however cost you less to operate, reduce the fine particle pollution in your area, and help keep your neighbors on speaking terms with you.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    If an EPA stove could brew beer there would be NO conversation on how awesome they are. It would just be common knowledge.
  20. brenndatomu
    BINGO! The pollution that wood stoves make wouldn't even register on the scale compared to forest fires, volcanoes, etc, etc, etc!
