Enviro EF-3 Wood Pellet Stove Bay View - 40,000 BTUs Large 55lb Hopper. This stove is in great shape, very clean inside and out with a new steel fire brick backing. This stove now has a brand new High Quality Gleason-Avery Auger motor, Brand new Enviro Auger and upgraded Nylatron Auger Bearing and EndPlate. Nylatron keeps the auger turning freely so the auger motor lasts much longer! 300 watt ignitor automatically fires stove in 5-7 mins! Proffesionall cleaned and serviced, this is ready to go. Call Don - 603-553-7402 $1295.00 See pics below: Brand new this stove is $3495.00 delivered and installed -- see link link http://www.masterspelletstoves.com/productdetails/EF3BI.php Manufacturer's Dexcription and specs The Enviro EF3 pellet stove is the slightly bigger brother of the EF2 with a more powerful igniter and greater heat output through a double row heat exchanger. The bay window design provides a good view of the fire.. First produced in 1991, the Enviro EF3 is good value and has stood the test of time. This stove is simple and easy to maintain. It has a long burn time on the low heat setting. Heating area 1,800 sq.ft. Max. Heat Output 40,000btu. Automatic Ignition Yes Manual Ignition If needed Hopper Capacity 55lbs. Burn time Over 55 hrs. Fuel Type Standard or premium grade wood pellets Glass Air Wash No Built in Blower Yes Convection Blower Capacity 160cfm. Thermostat Compatible No E.P.A. Approved Yes Emissions 1.96 gr./hr. Efficiency 78% Dimensions Height 30.5 in. Width 22 in. Depth 24 in. Weight 240lbs. Window Size 19 in. by 8 in. Flue Vent Size 3 in. Top Vent No Rear Vent Yes Rear Vent Height 16.4 in. Battery Backup No See Stove Sentry Surge Protector Recommended Colours Black Exhaust Temperature Sensor Yes Low Draft Shutdown Yes Construction Type Fabricated steel Automatic Shutdown and Re-ignition No
