Englander NC30 owners - the good, the bad and the ugly...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marvin, Nov 25, 2018.
  1. Marvin
    Marvin
    Huntingdon, Pa
    Just looking for some info on the NC30. I'm thinking about putting one in. My Osburn 2200 does a pretty good job heating my house from the basement but I'm afraid its gonna struggle when it gets really cold keeping heat overnight and while I'm at work.
    The NC30 kinda caught my eye with its huge firebox. So I'm curious now....how do you like yours? Any issues? Etc etc...
    mat60, wildwest, Chaz and 2 others like this.
  2. Jerriod74
    Jerriod74
    Loudon tn
    Following
    mat60, wildwest, HDRock and 3 others like this.
  3. Locust Post
  4. brenndatomu
  5. papadave
    You rang? (in my bestest Lurch voice)
    Hmmm, let's see.....
    The handle is too loose for my liking although it doesn't affect the burn. I like the Drolet handle MUCH better (similar size firebox, don't remember the model).
    I would LOVE some sort of secondary air control. It benefits quite a bit from a convection deck.
    It's pretty controllable, but once those secondaries start rollin' along, you better have a good idea what you're doing (hence my desire for control there)....it likes to run.
    When you don't need tons of heat (like today, it's mid-30s), use small 2" splits. Burns nice that way.
    If you can find the deal in Feb-March, it's well worth the price.
    I'd rather have a Woodstock or Blaze King. :whistle: I might think of more later.
    What brenndatomu said.:dex:
    mat60, wildwest, Maina and 6 others like this.
  6. Marvin
    Marvin
    Huntingdon, Pa
    Good info. Keep adding as you think of more pros/cons. This is just an idea I had and I thought I'd find out more.
    I guess when it comes down to it, would you buy again or look elsewhere is the most important question.
    mat60, HDRock, Chaz and 1 other person like this.
  7. Chvymn99
    It benefits quite a bit from a convection deck. And Blower... will extend the heating time.
    It's pretty controllable, but once those secondaries start rollin' along, you better have a good idea what you're doing (hence my desire for control there)....it likes to run. Definitely agree with this statement.... and mine will cruise at around 700-800 F on the top center spot with my thermal gun.
    If you can find the deal in Feb-March, it's well worth the price. I found mine brand new on Craig’s list it was just used at a demo show... got it fairly cheap.
    I'd rather have a Woodstock - yes that my ideal (no pun intended) stove...
    Would I buy again.... yes it’s a perfectly good stove for the price... but the only reason why I’d go to the Ideal stove is the ability to add the bling... bling....:D... plus they just look good...:D... sexy if you will...:cool:...
    I like the bigger wood I can use vs. the NC-13 that I previously. The center dog house will burn through wood...
    I’m upgrading my blower to the bigger blower in the next week...
    Good start papadave
    :handshake:
    wildwest, Thor, HDRock and 3 others like this.
  8. papadave
    Oops, I forgot the blower, but it does come with the "hair dryer" version. I upgraded to the nicer one.
    For my circumstance, at the time, it worked...
    Like I said though, I'd prefer a better stove and at some point, that may happen. I check CL occasionally.
    HDRock, Marvin and Chvymn99 like this.
  9. DaveGunter
    DaveGunter
    It's a great stove, and you can't beat it for value.
    I don't like that the fragile baffle boards are exposed/vulnerable to damage.
    I don't like that the OAK does not supply all of the combustion air.
    The ash pan us useless.
    If I were buying again I'd look hard at the Drolets, I think the biggest one is called HT2000. They are a bit more money. If I could buy whatever I wanted I'd get a Woodstock Ideal Steel.
    Maina, Chvymn99, HDRock and 3 others like this.
  10. papadave
    Not completely, but pretty darn close. :picard:
    Good point, and I was just thinking that yesterday. Don't know how colder secondary air would affect that burn though.
    Uh.....yeah. Even if you don't whack 'em every once in a while, they begin to deteriorate after about 3 years.
  11. HDRock
    Don't know why I got called up :) cuz I don't have one But From what I have read on here They are very good value .
    You want a bigger stove ? Get yourself out Lopi Liberty :DYou won't find any fragile baffle boards in That puppy:)
  12. brenndatomu
    Woops...should have put a "IIRC" in front of that list :whistle: ;) :D
  13. HDRock
    Hey, I can't keep track of all you yahoos on here either :D
    wildwest, Thor, Chvymn99 and 4 others like this.
  14. yooperdave
    I have an nc-30 in the workshop...........ah..........err..........rec-room in the garage. I don't use it 24-7; no where near that.
    Yeah, I really like it. I have never used the ash pan (on any of my three epa stoves for that matter) and agree that the baffle boards above the secondary tubes do occasionally get bumped, but I'm not one to throw or force chunks into the stove anyway.
    I use only the fan that was supplied with the stove-the hair dryer variety and am glad that it isn't in the house as it is noisy. I do not have a convection deck for it (yet) as I will occasionally cook (chili/stew) on top of the stove.
    The room that it is in measures 14 X 24 with 9" walls. It'll heat that up in the dead of winter to the 50's usually within a little over an hour.
    Opening the double doors to the garage (24 X 24) and you start all over once again. The other morning, I had the garage area up to high 40's low 50's and the rec room was at upper 60's thanks to the ceiling fans.
    wildwest, Chvymn99, papadave and 3 others like this.
  15. Highbeam
    Highbeam
    I have one and it’s my barn stove. I run it hard and got with an aftermarket blower and hand made convection deck. Aim for 700 stove top temperature as much as possible.
    I did manage to melt the thin air wash plate right inside the door at the top of the opening l. It sagged but is still very functional. Just don’t leave it at full throttle during warm up.
    I like the latch, the gaskets, the steel thickness, and of course the price.
    If I were to replace it I would try for a furnace for even more output.
    I have been able to regularly get smoke to run backwards through the secondary intake. It’s a startup thing with the door wide open but a fun nuance.
    Buzz Benton, Thor, Chvymn99 and 4 others like this.
  16. bushpilot
    bushpilot
    Eastern Washington
    It is a solid budget stove. I got mine for less than $750 delivered in the annual HD spring deal.
    It is a serious heater, probably about as good as any when running hard. Low and slow the cat stoves will mop the floor with it. I burn all softwoods but can get an all night burn (coals for relight in the morning) in deep winter if I load it up.
    It is quite controllable and simple to run. Light with the door ajar, close the door when flaming well, and push the handle halfway in when it is getting hot. Pull the handle full out when it starts cooling down. Most of the time that is all.
    Get the upgrade blower, for sure.
    It is the only source of heat in my 1700 square foot house in Northeast WA, and does the job. I would buy the exact same stove if I were buying again, but would look at Wood Stoves, Wood Stove Inserts and Pellet Grills - Kuma Stoves if you were buying it for me :)
  17. Woody Stover
    Woody Stover
    Southern IN
    Yeah, according to the EPA output numbers, going to the 30-NC won't be an increase in heat. Granted, running on high to attain that top number isn't going to leave you much in the box by the time you get back from work. If you don't want to fork out for a Liberty, I'd look at some of the Stove Builder, International (SBI) value stoves with a big box.
    The EPA numbers corresponded to my experience with the stoves I've run, the Dutchwest 2460 vs. the Woodstock Keystone and Fireview vs. the Buck 91. I'm not sure their numbers on other stoves are 100% reliable, however.
    This first link is the most recent list, but I had trouble opening that .xlsx file. The second link is dated, but shows the high output numbers for the Osburn and Englander.
    List of EPA Certified Wood Stoves | US EPA
    https://www.epa.gov/sites/production/files/2015-11/documents/pre2015nsps-certifiedwood.pdf
    HDRock and Marvin like this.
  18. brenndatomu
    Several people have mentioned the "big spring sale" on the NC30...assumingly referring the HD sale that could be found if you plugged "the right store #" in...that hasn't been done since spring of 2015 or '16 as far as I've heard...and many people have looked!
  19. yooperdave
    Thats when I got mine. I didn't realize it had been that long already! Used Durango Colorado for the store.
    HDRock, Marvin, bushpilot and 2 others like this.
  20. bushpilot
    bushpilot
    Eastern Washington
    Same here.
    HDRock, yooperdave and Marvin like this.
