Englander 'lower button' question
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by krooser, Dec 28, 2015.
  1. krooser
    krooser
    Waupaca, WI
    My 25 pdvc seems to be eating pellets at a faster rate than it did last year. One of my 'helpers' was pushing too many buttons a few weeks ago when starting the stove... gotta think that was a problem.
    I adjusted those lower buttons once before...4-6-1 I think? Right? Wrong? Who cares?
    wildwest, ivanhoe and slvrblkk like this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    That looks right kroos...if you have heat setting on "1" and it's still feeding too many pellets you can drop the first number to "3" or close up the feed gate in the hopper slightly.
    wildwest and ivanhoe like this.
  3. imacman
    imacman
    Denver, NC
    You're correct on adjusting the first # down if it eats too many pellets, but AFAIK, no Englander stoves have a "feed gates".......it's all done w/ the control board.
    If I remember correctly, the 25-PDVC is factory set to heat range "D", and bottom buttons are 6-4-1.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Pete, the pdvc's and pdv's have a small slide plate in the bottom of the hoppers....maybe the corn model too I'm not sure of that one.
  5. imacman
    imacman
    Denver, NC
    OK, thanks.....never knew they had any. The 10-cpm didn't.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    My EP doesn't have one either....not sure about the other models....wonder why they installed them though cuz like you said you can control it with the controller.
    IHATEPROPANE, wildwest and ivanhoe like this.
  7. T-Stew
    T-Stew
    Well I wish mine had an adjustable gate! Some of the models like my PAH and similar units come factory with feedrate set at its lowest possible rate. No way to go lower. And mine feeds at about a 25% higher rate than the specs say.
  8. imacman
    imacman
    Denver, NC
    As has been mentioned previously to you, call Englander Tech and ask for Mike Holton. If the controller program is messed-up, he's the guy who can figure it out & get it corrected.
  9. krooser
    krooser
    Waupaca, WI
    I get confoosed with all those led #'s and buttons... I'm just a simple man.
  10. T-Stew
    T-Stew
    No need to delve into my issues on this thread, I was merely saying I'd like that adjust-ability on mine (even without any other issues). Ironically the stoves that have the adjustable gate can also adjust lower via the control panel, while the stoves that can't adjust lower don't have the grate. I think it was the basic design of the single auger vs the dual auger design... none of the single auger top-feed units have adjustable gates if I am not mistaken (but I'm not familiar with them all).
    IHATEPROPANE likes this.
  11. krooser
    krooser
    Waupaca, WI
    Well I closed the slide plate tonite... I'll have a good idea if it helped in the AM.
    imacman and IHATEPROPANE like this.
  12. imacman
    imacman
    Denver, NC
    There are other heat "programs" built into the Englander control panels software. Occasionally, they get changed due to spikes in current, young children playing w/ buttons, etc, etc. They can also be changed on purpose to increase or decrease pellet use. Only someone at Englander could tell you if that needs to be done. THAT was the ONLY purpose of my comment. Period.
  13. krooser
    krooser
    Waupaca, WI
    Seems my pellet consumption is down 25-30%. Heat is down, too but not enough to worry about. Before closing up the gate I'd burn a full hopper (30 lbs or so) in 12 hours on #3. Last night it went 12 hours and had about 5-8 lbs left in the hopper.
    imacman and slvrblkk like this.
