Endurance 50F - Heat tube access panel bolts
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by NorthernCrew454, Jan 27, 2019.
  1. NorthernCrew454
    NorthernCrew454
    NE WI
    Hello all,
    I was prepping the new to me 50F this morning for installation and decided to do a good cleaning. When I went to remove the access panel over top of the heat exchanger tubes all 4 bolts broke off flush. My first idea to fix this would be to drill out the broken bolts, tap the next size larger, and install Stainless allen head bolts. Am I on the right track here?
    NC454
    jtakeman and ivanhoe like this.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    Try turning them on the inside to remove them first and replacing them with stainless is what I've done. I replaced all screws protruding into the fire chamber the same way.
    jtakeman likes this.
