Elm question
Discussion in 'The Wood Pile' started by Yawner, Dec 24, 2022.
  1. Yawner
    Yawner
    Louisiana
    Yep. Elm. Couple of elm trees (after limbing... logs) I let lay on sandy ground for a year until the bark is falling off, as per recommendations on this site. So, yep, the elm split just fine. A minority provided somewhat stringy splits but not much different from hickory. No real uglies in the mix. So, how long to season? I am getting about 35% moisture, does that seem 'normal?'
  2. MikeInMa
  3. Ohio
    Not Ohio
    Firewood BTU & Drying Chart
    This chart in the resources section is spot on. It might take longer if the wood is stacked in a shaded area or just piled with no top cover. Or if stacked top covered in a sunny windy area it could cut the time down.
  4. Ohio
    Not Ohio
    Jinx
  5. Yawner
    Yawner
    Louisiana
    But does the year it lay there in log form take some off seasoning time?
  6. JimBear
    JimBear
    Doubtful
  7. oldspark
    oldspark
    NW Iowa
    Agree, if chunked up and stacked yes log form no.
    T.Jeff Veal, theburtman, Ohio and 4 others like this.
  8. buZZsaw BRAD
    Give it a year then burn away. Some nice looking firewood there Bill. :thumbs:
  9. Horkn
    Not really. Once split give it a summer. It'll be dry then
  10. yooperdave
    Once again, there is no significant drying or seasoning for logs.
    There are exceptions, as always, to this rule of thumb.
    But if you are getting an MC reading of 35%, well you already know this. Some of the "winter cut" logs I got last spring had the same MC when cut and split. :handshake:
  11. SD Steve
    SD Steve
    South Dakota
    Everyone should read this chart, so many questions can be answered with it.
  12. ole
    ole
    Rock County Wisconsin
    I don’t know who made that chart but I believe it is subjective.
    In my experience, American Elm throws twice the heat as Basswood. Unlike what the chart says.
    Maybe it’s a regional thing,,
  13. brenndatomu
    Totally agree
  14. Scotty Overkill
    Elm is a waterhogging wood. In rounds, it won't season very well, if at all. It needs busted open in order to season.
    I've cut standing dead American elm that had no bark and was pretty much ready to burn off the stump, all but the very thick logs at the base of the tree. But standing dead, vertical and barkless, it seems to allow gravity to help eradicate the moisture. Laying down, not so much.
    Hinerman, Timberdog, walt and 11 others like this.
  15. Horkn
    Fully agree. American elm here a bit east of you, sure throws a lot of heat.
  16. Rick Capper
    Rick Capper
    Pennsylvania
    15 yrs ago during the height of Dutch elm disease here in pa,we would cut down and split barkless elm and burn it right away.burned great.but it was a bear to split.we we would always put a round behind the round that just was split to push through the the remaining fibers.
  17. buZZsaw BRAD
    My recent experiences with cutting year old+ logs that is if C/S in the Spring they are ready for the following burning season. One year drying woods of course...maple, birch, beech etc.
  18. buzz-saw
    buzz-saw
    Ct.
    I had a load or two a year or so ago that was dead when it was cut and most had no bark. I split it and stacked it in the spring and burned it next burning season a little later on in that season.
    Burned great , maybe a little stingy for some; but the hydro didn't know any different.
    That pile you have looks great and should dry no problem.
  19. Wishlist
    Wishlist
    Corunna
    I really like standing dead elm with no bark . I cut a lot of it every year to keep it from falling on the sap lines . Not huge stuff but I’ll fill the kubota and take it home and it goes right inside the house . No stacking or splitting ! Burns great and not messy at all.
  20. theburtman
    theburtman
    I've been cutting standing dead elm at my neighbors when the weather is right. Most is barkless except for the bottom few feet. I top off my wood rack on the porch with 4 to 8 inch diameter limb wood that is dry as can be every time I bring some home. The bigger pieces I separate by bark/barkless and stack. One day last week when temps had been well below freezing for a few days I tried some with the x27. The barkless split ok for the most part. The pieces with bark were next to impossible. So as discussed here I'm going to leave them for about a year.
