Echo 60S
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, Feb 9, 2016.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Is it worth $40? Found it on CL
  2. clemsonfor
    The parts are worth that easy. You could part it out and probably net $100 on ebay. May take time but you could do it.
    pantelis, HoneyFuzz and Barcroftb like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Being an ECHO goof ball I'd be fixing it up and keeping it.
  4. clemsonfor
    Some of those parts are harder to find. Looks like a good bit older saw. I have a 451 that I am in the process of getting back working . I had the recoil fly apart on me as I took the wrong thing apart changing the rope. Now its a giant paper weight till fixed.
  5. NH_Wood
    NH_Wood
    If it's a runner, top end is in good shape and all the basics are good - $40 is short money. Cheers!
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2 !
    pantelis likes this.
  7. Barcroftb
    Barcroftb
    The Mitten
    pantelis, clemsonfor and HoneyFuzz like this.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Seller says it runs, stalls at idle and hard to start hot...
    pantelis and clemsonfor like this.
  9. clemsonfor
    I dont think you can go wrong
    HoneyFuzz and bobdog2o02 like this.
  10. Eric VW
    Do it Bobby:thumbs:
    pantelis, HoneyFuzz and bobdog2o02 like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    Get out there and get it!
  12. Barcroftb
    Barcroftb
    The Mitten
    Great opportunity to put your tach, carb tools, and new found carb tuning skillz to good use.
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    exactly what i was thinking.
  14. Shawn Curry
    Shawn Curry
    Western NY
    Yeah it sounds like it's running too lean. I've also heard of some older Stihls like 041 had a faulty ignition coil that caused similar symptoms.
  15. pantelis
    pantelis
    Europe
    hard to hot start maybe coil or rings but anyway its worth the 40
    NH_Wood, Eric VW, Barcroftb and 2 others like this.
  16. clemsonfor
    I have an 032 that I'm leaning towards bad coil. It was running but kind of all over. Not idle well then it stopped on me. If its coil I bet its cause it was warm.
    I had a husky 372 that I though was a bad carb as it would crank up fine but not idle or run long or well. Then would just stop. Let it sit a day and fire up but ran all wanky. The more I messed with it I thought coil. I had a parts saw so I swapped coils and that was the issue.
    pantelis, Eric VW, Barcroftb and 2 others like this.
  17. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    We shall see, I'm waiting to hear back from the guy. he was asking $60, the cheapo in me offered $40, he said nope. I replied with the old saw, hasn't run in a year and parts are tough to find. We agreed on $50 son now I'm just waiting for the call for when and where to pick it up.
    Eric VW and Barcroftb like this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Barcroftb and Eric VW like this.
  19. Barcroftb
    Barcroftb
    The Mitten
    Although less common, I've had air leaks cause similar issues as well.
  20. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I was thinking the same thing with a saw this old, carb rebuild and new fuel lines.....
