Echo 4910
Discussion in 'Chainsaws and Power Equipment' started by Elm-er Fudd, Oct 22, 2023.
  1. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I have heard rumor that echo discontinued the 4910. Anyone know if that is true? If so I need to pick another one up before they disappear. Awesome 50cc saw for the money. If discontinued, are they replacing it with something similar???
    Screwloose likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Yes. Replace by a plastic clamshell saw the 4920. Heavier too.
    The CS-501P is the same saw internally as your 4910 with the addition of the aluminum handlebar, captured bar nuts and Echo's older style all orange look. Lightest 50cc saw made they say.
  3. T.Jeff Veal
    Get a 4910 while you can. Send 1 to huskihl for XS. Only saw you would need for general farwood cutting.
    dennish, Horkn, metalcuttr and 5 others like this.
  4. T.Jeff Veal
  5. Czed
    Czed
    Wv
    My friend bought a 4920
    I had a 4910 for four years I liked it better than the clamshells.
  6. Biddleman
    Biddleman
    River Hills of Pennsylvania
    BEAST MODE!
  7. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I may pick one up and send it to huskil. I’m very impressed with the one I have with just a basic muffler mod. It will easily outrun my buddy’s ms 261 both with 20” bars, buried in dead dry Siberian elm, and new identical chains. The 261 is stock with a modest muffler mod. One with the extra sausage would be a lot of fun. Me thinks it would probably run with my 620p at a whole bunch less weight.
    Horkn, metalcuttr, Screwloose and 3 others like this.
  8. T.Jeff Veal
    Yes sir, my go-to saw now for regular size firewood
  9. T.Jeff Veal
    XS almost doubles the HP. Don't normally cut logs this big with it, but nice to see it can handle it, if needed.
    Horkn, metalcuttr, Screwloose and 4 others like this.
  10. buZZsaw BRAD
    Uh oh! The 029 becoming a shelf queen?
  11. Eggshooterist
    Eggshooterist
    Erff
    Cut very well and it sounds like you are tuned quite conservatively even.
  12. RCBS
    RCBS
    Over here
    I wonder if the 502P will be any heavier than the one I have?
  13. Eggshooterist
    Eggshooterist
    Erff
    He weighs them in this vid. If I recall correctly they are within a tenth or two of each other.
  14. Elm-er Fudd
    Elm-er Fudd
    Kansas
    Of the dozen saws I have, the 4910 is the one I grab first unless I’m cutting big stuff. Usually take 4-5 saws when I go on a wood cutting adventure. 4910 is the one that ALWAYS makes the trip. Also adds another hour to my cutting when I’m tired of running the big saws toward the end of the day.
    Horkn, metalcuttr, eatonpcat and 5 others like this.
  15. T.Jeff Veal
    It gets more breaks than it used to. It's just heavier. If we have a good bit of 18-20" logs, I'll probably use it. 3/8 chain cuts faster than .325
  16. BuckeyeFootball
    BuckeyeFootball
    I have the OG Echo 490 its been a great saw and is usually my go to with a 20" bar. Maybe Ill snag a 501 before theyre gone.
  17. RCBS
    RCBS
    Over here
    Think they'll clam them? I look for a filtration upgrade on next iteration. I have to think that they will always have a 'pro' saw for the 50cc class.
  18. Eggshooterist
    Eggshooterist
    Erff
    Id have trouble not buying a 501 if they udate the filter.
  19. Barcroftb
    Barcroftb
    The Mitten
    I bet an update would include spring av too.
  20. Eggshooterist
    Eggshooterist
    Erff
    That would be excellent.
